Posts: 23.1K,
Visits: 36.6K
grapelemonswirl (7/25/2022) Go into the screen settings and get your "zoom" setting to 100% or lower, resolution doesn't help.
Also, who the hell oversaw this? Like, make the windows resizable ffs.This issue only occurs in CC3 when you are using a screen resolution below the recommended 1920 x 1080. However, in CC4 the Export Panel is scrollable so the issue no longer occurs.
grapelemonswirl
grapelemonswirl
Last Active: 9 Months Ago
Visits: 54
Anonymous
Anonymous
Visits: 22
I ran into the same issue. My workaround in windows 10 is: prepare all your settings in the export window go display settings (right click on desktop) scroll down to screen orientation, and chose portrait tilt your head to the left (or right) press export ^^
backalleytoonz
backalleytoonz
Last Active: 4 Months Ago
Visits: 8
Please go to window, and check the workspaces options. I set mine to standard and it fixed the problem. the low res does too. it was set on 1920 x1080 which made the export window too long on my laptop. Glad i finally found it too lol.
backalleytoonz
backalleytoonz
Visits: 8
meiteisingh0
meiteisingh0
Last Active: 6 Years Ago
Visits: 6
Thank you guys for giving me an advice...anyways now its working..i just change the screen resolution, atleast i can export fbx..as i followed this video tutorial.. https://www.youtube.com/watch?v=6iDtcGpG3_w
Posts: 23.1K,
Visits: 36.6K
@charles_samuel2000, @meiteisingh0 This issue occurs when your screen resolution is too low. Please share your system specifications including graphics card. If you have a compatible graphics card it will certainly allow you to choose a suitable resolution like 1920 x 1080. If you don't have this option you may be using an incompatible graphics card.
Visits: 22.1K
What the heck kind of card are you running? You need to be using at least an NVidia 1060 (1070 or 1080 would be better). CC3/iClone *will* run on lesser cards, but not well. Might be time to upgrade your card (I've honestly never had a card that couldn't do 1920x1080, at least in this century).
meiteisingh0
meiteisingh0
Visits: 6
Visits: 22.1K
What screen resolution are you running? Try 1920x1080.
