i2k
Last Active: 6 Years Ago
Visits: 88
rosuckmedia (9/1/2019) @kyodev, Thank you for your help, but I can not get it. Usually I do not give up so fast.:) Greeting rosuckmedia
 Hi, your path is incorrect, it should be "C:\Program Files\Reallusion\iClone 7\Bin64" Feel free to ask any question :)
Bill
Posts: 5.7K,
Hi Bill, I got everything installed, but the camera doesn't move using the keys and "stutters" with the mouse. I'm using iClone 7.6.
i2k
Visits: 88
wires (9/1/2019) Hi Bill, I got everything installed, but the camera doesn't move using the keys and "stutters" with the mouse. I'm using iClone 7.6.Glad to hear that everything is installed. This error actually comes with the iClone 7.6 patch as indicated in the image below  This update prevents the plugin from constantly updating the viewport of the camera. So the solution is to turn off the Reduce Idle Load option in the Preference tab of iClone, and everything should work just fine :)
Bill
Posts: 5.7K,
Thank you Bill, it looks as though this "new feature" in 7.6 may cause more issues than it solves for some users.
i2k
Visits: 88
You are welcome :D Well it may be problematic for some, but yeah for the meantime all we can do is to adapt
Bill
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
@kyodev My last try, does not work. See picture Am I writing the line wrong?:D I'll try it again tomorrow Greetings Robert:
i2k
Visits: 88
rosuckmedia (9/1/2019) @kyodev My last try, does not work. See picture Am I writing the line wrong?:D I'll try it again tomorrow Greetings Robert:
 Hi Robert, your path is still incorrect at some places, which have been pointed out in the picture below. Also, please tell me if you are interested in debugging this step by step or that you only want to make the plugin run with no further frustration :) I will adapt to your needs.
Bill
i2k
Visits: 88
To whoever seeking help about the plugin in this thread,
I will be on vacation for one week. You can leave your requests here and I will answer them all at once this Sunday.
Thank you,
Bill
Posts: 5.3K,
Visits: 16.8K
@ kyodev Robert is using German version of Windows, so "Programme" is translated as Programs and seems to be correct. @ rosuckmedia When you open cmd, it shows a directory and a prompt. In your case it is: C:\Windows\System32>_At this point you have to enter the command cd, (which stands for Change Directory) following by the actual Bin64 path, so that whole line should look like: C:\Windows\System32>cd "C:\Programme\Reallusion\iClone 7\Bin64"After you hit Enter the prompt should change to: C:\Programme\Reallusion\iClone 7\Bin64>So that you can execute next command with executable which is located in Bin64 folder. However, for some reason you end up having some other path: C:\Users\Robert> at the prompt, while Windows expect to have a command there. And that is why Windows displays the error (I did not translate it). So just get rid of C:\Users\Robert> and you would be fine.
Visits: 62.6K
Well darn! I got my own set of errors. :)
