Hi everyone, I have returned from the trip! Here are my answers to your questions
4u2ges (9/2/2019)
@ kyodev Robert is using German version of Windows, so "Programme" is translated as Programs and seems to be correct.
@ rosuckmedia When you open cmd, it shows a directory and a prompt. In your case it is:
C:\Windows\System32>_
At this point you have to enter the command cd, (which stands for Change Directory) following by the actual Bin64 path, so that whole line should look like:
C:\Windows\System32>cd "C:\Programme\Reallusion\iClone 7\Bin64"
After you hit Enter the prompt should change to:
C:\Programme\Reallusion\iClone 7\Bin64>
So that you can execute next command with executable which is located in Bin64 folder.
However, for some reason you end up having some other path: C:\Users\Robert> at the prompt, while Windows expect to have a command there. And that is why Windows displays the error (I did not translate it).
So just get rid of C:\Users\Robert> and you would be fine.
Thanks
4u2ges for helping me out!
Rampa (9/2/2019)
So it installed correctly with admin rights.
But middle-mouse click on the scene does not open it for me yet. Mouse must be mapped some other way, or it is less installed than I thought.
Hi
Rampa, I have sent you a private message to work on this issue. Hopefully I can help you fix this and post the solution here for others.
Thanks for the advice!
richard666 (9/2/2019)
This is a fantastic idea and one im so interested in BUT i have never written code and im afraid i will mess up something critical if i try.
Is there any way you could develop this without having to do code?? Of course i believe the work involved requires charging for the plugin and i would certainly pay for this.
i have been preparing scenes for potential simulator use and this plugin goes along way towards doing this. I have been learning Unreal and Unity because iClone cannot do what i want BUT this plugin could change things. What do you think about working on a simulator project? Its good for Reallusion and definately good for me!! and could be for you too!
regards rich
Hi Rich, I cannot get your question, can you explain what you mean by saying "Is there any way you could develop this without having to do code"?.
If you are thinking that this plugin requires programming in order to get it work, then it is not. The installation of this plugin needs no programming background, and you can make it work simply by following the tutorial video.
On the other hand, if you are asking for a command-free setup, then you can confirm the demand in this thread and I will build the command-free setup in the next update. No need to pay, I will do it for free.
rosuckmedia (9/3/2019)
@kyodev
@4u2ges.
Hello, I did it, a German user helped me too. (Jünni) Thanks to everyone.
Greeting rosuckmedia
Glad you had made it!
Bill
5 Years Ago by
kyodev
