TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
Bassline303 (1/15/2021) I am not sure , but I guess Recording Material changes is not possible with sequence recorder. But why sequence recording when you have it already as sequence (keys) You can save the Sequence as " Create Linked Animation Sequence" or "Bake Animation Sequence" and load it any time you want....reassign a Character , as long as it has the same Skeleton/Material Names ...so CC3 should do it.
but to be really sure I would need to have a deeper look....
oops , or do you mean recording material changes from IClone via LL?
Okay, just was interested to see if you ever heard that was possible or not. I'm imagining a material reacting to music, and imagining that this reaction-parameter was being recorded by the Seq Recorder. As far as why, given that you can key, well that's just me - I am lazy and looking for a shortcut! I am not thinking of iClone driving material changes in UE4 through LLink, although that is interesting that you mention that. But I think with iClone-LL-UE4 materials are detached, right? I'm thinking a change in diffuse-color, or roughness, of a material in iClone won't, through LLink, then adjust the color or roughness of the corresponding material in UE4.
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
For Audio Reacting you can use a blueprint by "Arthur......" it records peaks of Bass -Mids -Treble to keyframes. You can use this keyframes to react to anything that is controlled by keyframes via copy and paste.
I did it with lights only....
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
Oh Cool...I will be checking that out.
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
TonyDPrime (1/15/2021) Oh Cool...I will be checking that out.
Here is my Tutorial & the BP to download ... scroll down a bit ..... https://forum.reallusion.com/419325/Tips-Tricks-for-Unreal-Engine-4?PageIndex=125
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
Thanks Bassline. You know what is another weird thing, the LLink skeleton vs FBX skeleton. I wonder if they are the same. 1) I create Avatar A.in CC3 LLink2a) Bring Avatar A into iClone 3a) LLink Avatar A to UE 4.26 4a) Avatar A now in 4.26 with "Skeleton A" Also: FBX Export to Maya2b) Export Avatar A from CC3 to Maya, with UE4 profile 3b) Following Smooth, export from Maya to UE4.26 4b) Attempt to assign Skeleton A (from 4a) to this import, and UE4 gives me an error that the bones do not match... 5b) import with its own Skeleton, but this new skeleton now does not match the Skelton A created by LLink, so no animations created for the LLink Avatar work on the imported FBX avatar, nor will it be recognized by a LLink avatar corresponding to its name.
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
Best working way is to import from Maya into UE4 with new Skeleton , then select the Maya Character in the Content Folder and go to "IClone Live Link" (above) and select "Create BB for selected Character". Add the Maya Character into the scene "under the Iclone Origin" , tick the Live Link Button in IClone and go to UE4 Character Details / Live Link / Name .... give it the Name of your Character in IClone.... ...works very well....
JoeGideon
JoeGideon
Last Active: 10 Months Ago
Visits: 1.7K
Hi Bassline303, I am a little confused about the Maya smoothing procedure. In an earlier post you showed that you used rubber band to separate the mouth from the rest of the character and then smooth subdivide (to get rid of bubble gum mouth effect). In another post you mention that there is a weight painting problem with the mouth and that has to be addressed by hand painting (I'm going by memory here, so I may be wrong with the terminology). Could you please clarify if you are able to get the mouth to work correctly after smoothing, and if so what are the steps involved (only selecting, or is there some weight painting)?
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
1. To exclude the lips from smoothing works. 2. If you don't want to exclude the lips , you have to skin weight repair the lips...
JoeGideon
JoeGideon
Visits: 1.7K
Thank you so much!
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
JoeGideon (1/16/2021) Thank you so much!Just further, weight painting was brought up after the fact as a 2nd potential remedy, but he had already discovered that excluding the lip polygon faces from the smoothing procedure would work alone. LOL - Sounds like doctors talking about an ill patient: "Doctor Bassline, there is something wrong with the patient's skeleton..." "Doctor Bassline, patient presents having an issue with their lips and mouth..."
