Tips & Tricks for Unreal Engine 4
Posted By StyleMarshal 6 Years Ago
150
151
152
153
154
507
rosuckmedia
rosuckmedia
Last Active: 7 Months Ago
Posts: 3.2K, Visits: 4.8K
Hi Bassline,
Upps,
Thanks for this Tutorial.:):)
Greetings Robert
TonyDPrime
TonyDPrime
Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)
Posts: 3.4K, Visits: 12.4K
Danke for this tutorial!
ant_127217
ant_127217
Junior Member (141 reputation)Junior Member (141 reputation)Junior Member (141 reputation)Junior Member (141 reputation)Junior Member (141 reputation)Junior Member (141 reputation)Junior Member (141 reputation)Junior Member (141 reputation)Junior Member (141 reputation)
Posts: 8, Visits: 261
Hi, people! ^)
Make character with morphtargets. Works very vell, but.
Export from CC3 to unreal with FBX (clothed character) Unreal setup.
There's some problem with EyeOccclusion morph.
In CC3 works fine, in Iclone not so bad and in Unreal 4.25 eye_occlusion mesh thorns through eyelids.
What im doing wrong or it's a bug with FBX export?
https://forum.reallusion.com/uploads/images/b74792c5-bb31-425f-ab9c-aecb.jpg
Video
rosuckmedia
rosuckmedia
Hello everyone
Power IK Live Link Blueprint
Did everything as in the tutorial (Bassline)
Somehow it doesn't work for me.
I tried it with a scene.
Will continue testing tomorrow.
What does this warning mean.
I added two pictures.
Greetings rosuckmedia:):)
https://forum.reallusion.com/uploads/images/8b928b4a-1f39-49a8-83a3-673e.png
https://forum.reallusion.com/uploads/images/950b05bb-8830-4c1e-be46-80db.png
StyleMarshal
StyleMarshal
Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)
Posts: 5.8K, Visits: 14.3K
Welche map ist das?
I guess it's your terrain....will test it...whats the name of the map ?
Fast Path is good !
Did you activate simulation in UE4 ?  (Alt - P)
Fast Path :   A quick summary is basically this: If one node in the ABP does not support fast path, your whole blueprint will be slower.
StyleMarshal
StyleMarshal
ant_127217 (12/15/2020)
Hi, people! ^)
Video
There was an issue like this before , then they fixed it...now in IC 7.83 it looks like the issue is back...I would write a ticket to RL support with the information above.
Did your test it with LL or only FBX Import ?
rosuckmedia
rosuckmedia
Bassline303 (12/15/2020)
Welche map ist das?
Fast Path is good !
Fast Path :   A quick summary is basically this: If one node in the ABP does not support fast path, your whole blueprint will be slower. It is automatically disabled if any node does not fulfill the requirements. If you want to make sure you have fast path fully enabled, try to pre-calculate all necessary variables in the event graph (or in code) and use only raw floats and bools in the animation blueprint.
Hi Bassline,
Thannk you for Testing
Greetings Robert:)
https://forum.reallusion.com/uploads/images/48a6aed3-fcce-4c9f-b9e8-eff9.png
StyleMarshal
StyleMarshal
Did you activate simulation ?  (ALT - P) ?
rosuckmedia
rosuckmedia
Hi Bassline,
Then it happens, unfortunately I can only continue tomorrow.:(
Greetings Robert
https://forum.reallusion.com/uploads/images/83c12459-8c97-4426-988d-7a5e.png
StyleMarshal
StyleMarshal
Works for me :
Looks like your Character is standing on something invisible.
Activate show collision and try another start point of your Iclone Origin :
I see , you have a Camera inside ,where is the Cam in UE4?
https://forum.reallusion.com/uploads/images/772ec51b-e5e3-400c-b849-ca3e.jpg
150
151
152
153
154
507
