StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
ok , then stay with Actor recording till I found the solution. BTW , here are others having the same issues like you and they are not using IClone to UE4 link:
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Bassline303 (7/4/2021) Hey Toy , I found something : It works when I let IClone LL ticked (activated) :w00t: Will do some more trial & error till I found the solution.Hm, does not work on my side...
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
toystorylab (7/5/2021) Hm, now I have the problem that MH does not follow xyz... :pinch:
EDIT forgot to wire something in BP, works now :blush: Damn, I want to animate, not wire things in BP! :crying: Though, as I get cooler renders it is worth the effort. :D
Yeah , it is all fresh stuff but it will be getting better & better , you are a pioneer right now :D
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
rosuckmedia (7/5/2021)
Hello all together, I have exported an Iclone CC3+ Charcter to UE. Now I want to use the Live Link Face app in UE. I need information about the Blueprint for CC3+ Character Face. Thanks a lot.π Greetings Robert Rob the Robert , 1. does the Audio Recording work for you? 2. Any information about LLF here : https://forum.reallusion.com/476282/How-to-Animate-CC3--Character-with-Unreal-Live-Link-Face:D
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Bassline303 (7/4/2021) Hey Toy , I found something : It works when I let IClone LL ticked (activated) :w00t: Will do some more trial & error till I found the solution.So, you did not change the blueprint but you just leave connection iClone/Unreal active? Will test...
rosuckmedia
rosuckmedia
Last Active: 7 Months Ago
Posts: 3.2K,
Visits: 4.8K
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
2020pierovarda (7/4/2021)
Bassline303 (7/2/2021) 1. be sure you don't use the old Meta Human Sample project. 2. be sure you are using LL 1.3.Thank Bassline thanks Tony finally after many hours i discovered my stupid mistake, everything was correct except i was coping one of the plugins with unreal engine opened and had noticed that I WASNT REALLY INSTALING one of the plugins sorry and thanks for the help ! Great! UE is a real pain with referencing folders and files, and it doesnβt seem to like updating mid stream. I often start a new basic test project just to make sure things seem in order after updating, that way I can isolate anything gone wrong. Then when I confirm I got everything right, I go back to the project I was working on.
2020pierovarda
2020pierovarda
Visits: 205
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
toystorylab (7/2/2021)
Bassline303 (7/2/2021) I plugged the cable into my wlan/wifi router and I disable wifi in the IPhone or switch to flight modus. You also can plug it directly into the PC.Ok, my router is too far away... Will see how I can use it. :pinch:
Have another problem now... I see character move when I play sequence but it does not show in render. :pinch:
