Setting up Affinity Photo to work with CA/CTA: a tip from the trenches :)
Posted By candlelight2007 6 Years Ago
Setting up Affinity Photo to work with CA/CTA: a tip from the trenches...
vepop
vepop
Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)
Posts: 1.0K, Visits: 9.9K
Agreed. The manual is somehow confusing.
Flash is used for the creation of the G2 characters.
You can use AD to create the G3 + 360 Head Degree turn.
When you are keen to create your own characters, I bet the best choice is the Pipeline version.
https://forum.reallusion.com/uploads/images/9331d0a4-6a4b-4e86-9f88-963f.jpg
YouTube Tutorials Here
denise.wilson1
denise.wilson1
Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)
Posts: 43, Visits: 687
I am responding to your comment, “that it should be clear and easy to find breakdown of some of the key features readily available rather than a bunch of isolated morsels of wisdom scattered all over the place. I often feel like I am trying to read between the lines browsing through manuals and tutorials over and over again, which more often than not are scratching the surface or giving you bits and pieces leaving you pretty much on your own to figure it all out.”  I so agree with this and although many tutorials are titled ‘beginner’ or ‘basics’ – they don’t deliver.  I have been struggling with this software (CTA) for over 3 years and still don’t feel I have a handle on how to create characters. I would like to think that CTA4 pipeline would be my salvation – but my more practical and rationale side knows this is just self-delusion.  These are some of my unanswered basic questions:
·      If you don’t have photoshop (for all the tutorials refer to photoshop) can you really do anything in CTA?  (I can’t afford photoshop, can barely afford CTA) I now realize from this post I can use AD - thank you for that.
·      Can you only get the templates if you have the Pipeline edition?  If so, why even offer a Pro edition, let alone a standard.
·      And then, when you go to the manual, they talk about Flash!  What is Flash?  It seems it is critical to the process.  So, should you import into CTA in .swg, .psd or .png? Someone needs to explain when you do which – I’ve seen tutorials where they tell you to export in .png to CTA – or do you export into CTA with .psd.  So confusing!  And what about Flash??
·      And how do you make sprites for your characters?  All the tutorials have them ready-made – but they are not the parts I would need for my characters.  Where can you get(buy) sprites?
·      And the templates – if you can get them – do you have to go to your outside editor to use? – or can you use them in CTA to make a character?  What’s the difference between these psd templates and the templates they have under G3 characters in CTA, or the G2 ‘Simon’ Template?  Also, what’s the difference between the ‘motion bone’ templates and the ‘dummy’ – what’s the dummy used for?
Believe me, the questions I’ve listed here are only the tip of the iceberg - reflecting only my most recent struggles.  And I’m sure some of these questions are naïve or, in fact, stupid.  But I don’t have an animation background and I had hoped I would be able to learn how to do it with CTA.  Well, 3 years later and I still can’t create my own character and animate it without the head falling off. However, I can attach props on G3 characters, but not on G2 – does G2 use a different process? You see my dilemma – I would need tutorials that explained what would appear obvious to more experienced animators.  CTA for Dummies.
willemsince1977
willemsince1977
New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)
Posts: 1, Visits: 70
Thank youso much for this. I have been working in Affinity Designer for the past 2 years,but could never figure this out until coming across this post.... It does feellike magic now :-) !!!
vepop
vepop
No problem on my part.
Just need to tick a certain folder and lock it.
The content inside the folder needed to be checked.
For Mask, untick the folder while the content is ticked and checked as well.
desupero
desupero
Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)
Posts: 7, Visits: 33
I'm not sure whether it's a recent update or something else but I followed the PSD template video using Affinity Designer and ended up with lots of body parts missing. There seems no sense a to why. I made sure all layers were checked as visible, looked to see if any were further in the hierarchy than others, but no joy! It looks like it's only taken the very top layer in each group and left the others out. I really hope that they put together an A.D character PSD template video (or simply design one for A.D.), as A.D. is now been used by so many people instead of Photoshop. Any ideas as to why my body parts may be missing when I open it in C.A. please?
candlelight2007
candlelight2007
Posts: 73, Visits: 336
Well I can only speak based on my own experience. And I cannot compare Affinity with PS because I don't have the latter. All I know is that Affinity is working for me the way I expect it to: meaning it opens the character in PSD format with all the folders intact and then reimports back into CA without a problem. If you would like to send me your CA project with this one character that is not working for you in Affinity but is working in PS I will be willing to take a look.
johnb78
johnb78
Junior Member (124 reputation)Junior Member (124 reputation)Junior Member (124 reputation)Junior Member (124 reputation)Junior Member (124 reputation)Junior Member (124 reputation)Junior Member (124 reputation)Junior Member (124 reputation)Junior Member (124 reputation)
Last Active: 6 Years Ago
Posts: 11, Visits: 26
Having just re-read this thread I noticed you said :    johnb78: I may be missing something but why do you need to go to Photoshop instead of opening a PSD template right in Affinity and working there entirely? Affinity does a decent job with PSD files so all PSD templates work great in it for those of us who do not have/use Photoshop. It works for me anyway
Today i used the PSD template in Affinity , brought it into CA4  and my characters neck was missing ,   went back to Affinity make sure no mistakes made ,  then re-imported it again ,
now the face and the mouth is missing ,    So i dont think its possible to use the PSD template in Affinity and i am not surprised , i would guess the template is set to corrupt itself and not work correctly if it is not used in Photoshop ,   Adobe not making this template for the benefit of Affinity users and again i dont blame them ...
So i learned something important ,  if the template is not working correctly in Photoshop , just uninstall and then re-install Photoshop...
excuse the audio on below clip...
https://vimeo.com/348054711
johnb78
johnb78
I apologise for my rudeness and taking offence when i probably shouldn't  have ....   you've written a very concise and clear text there and it reads very well ,  i very much agree .
I uninstalled Photoshop and tried using the Front facing PSD template in Affinity to rig my most recent character  , So far so good ,  when imported to CA 4 the skeleton needed rigged even though the bone labels / markers were put in place on the template in Affinity ,   characters neck dissapeared too ,   made some changes in AFF then re-imported ,   characters face now missing , characters mouth and neck also missing ,    Conclusion : If using the PSD template to rig characters it has to be done in Photoshop and not Affinity ,  obviously Adobe have paid a few quid to Reallusion in order to be the software of choice for users of CA 4 , thats fair enough  , i've no problem with that .
needless to say i have re-installed Photoshop... i will be content to use Affinity as the external editor...
Earlier in the thread when i spoke of the ease of rigging a character with the PSD template ,  I tried to describe the process , but not very well ,    after you have placed all the parts of your characters head and body in the appropriate folders ,  RL Image for the body  , RL Talking Head for the head ,   you need to place the bone markers in place ,  with the MOVE tool selected its a case of clicking and dragging each bone marker to its correct location ,   now imagine instead of just clicking and dragging each marker , instead  , you had to first locate each marker in its folder before being able to place it in its location ,   if you had to do that it would take a while to rig a character...     well thats what happened in my Photoshop the other day , instead of 10 minutes to rig a character it became almost impossible ,    WHY ,  who knows....   What was the Answer =   Uninstall Photoshop  , re-install Photoshop  , hey presto normal working order is back ,   rig a character in less time than it takes to smoke a cigarette....      https://vimeo.com/348054813
candlelight2007
candlelight2007
:) it seems like miscommunication to me. It was never my intention to offend you in any way or invalidate your experience or downplay your frustration with some of the features not working as you would expect. And I'm sorry if it made you feel that way. I was simply trying to keep the discussion relevant to the topic of the post, that's all. The post was intended as a quick tip for those who need it. If I had that tip 6 months ago myself it would have saved me a lot of frustration, so I was trying to help the community.
On a side note, I am in the same boat as you are and I too have been banging my head against the wall for weeks on end and still am wishing there was a clear and easy to find breakdown of some of the key features readily available rather than a bunch of isolated morsels of wisdom scattered all over the place. I often feel like I am trying to read between the lines browsing through manuals and tutorials over and over again, which more often than not are scratching the surface or giving you bits and pieces leaving you pretty much on your own to figure it all out. And I too hate it when I hear answers like "here's the link" to a tutorial that I have read/watched a dozen times before posting my question and I agree that it does make you feel under appreciated sometimes. But at the end of the day we are all trying to make this tool - which does have a lot of potential - work for us.
johnb78
johnb78
I am grateful to have read this post and discovered that i can use Affinity instead of Photoshop ,    I uninstalled Photoshop and will now use Affinity with the PSD template and see how i get on...  my earlier rant is frustration about programs not doing what they say they can ,    one day something works  , the next day it does not ...
I take offence at your draw the line comment..
I do not wish to discuss this further and i do not want to send you a message  either   ,    if i did want to discuss further  ,   i will write in this thread ,   If i want to
Why don't you and your other veteran and distinguished members try helping out in the thread where someone is asking  questions about this program not doing what it is meant to   ,    but is being ignored or met with answers like   " go to the manual "
