fire particle emitter size change?
Posted By johnwarndt52 7 Years Ago
johnwarndt52
johnwarndt52
Posts: 145, Visits: 371
Does anybody know how I might change the size of the flame produced by a fire particle emitter? There are no size parameters in the modify panel for the fire that came with the iclone 7 that I bought, or in either of the two other fire particle emitters I've bought from the marketplace either. I thought I might reduce the size by attaching it to an object, then scaling that down, but that didn't work. As it stands, I may have to draw onto individual frames after I render to achieve the effects I seek, but that would be tedious in the extreme.  Any help with this would be greatly appreciated.
Rockoloco666
Rockoloco666
Group: Banned Members
Last Active: 6 Years Ago
Posts: 762, Visits: 2.0K
Is the fire particle a legacy or a popcornfx particle? (It should say so in the content manager snapshot) if it is legacy go to the modify tab and you will find a section named particle key there you must adjust the size in pixels for each of the four keys represented by a triangle. If it is a popcornfx particle and you don't see a popcornfx tab you need the popcornfx plug in in order to edit its parameters
mtakerkart
mtakerkart
Last Active: 10 days ago
Posts: 3.2K, Visits: 29.2K
If it's Legacy , you have 4 keys when you can choose the size.
https://forum.reallusion.com/uploads/images/c55ed067-4240-4077-9cec-81eb.jpg
http://manual.reallusion.com/iClone_7/ENU/Pro/Default.htm#iClone_7/Pro_7.0/11_Set/Particle/Adjusting_particles.htm
If it is popcornfx Library 40 particle there is a Global scale .
https://forum.reallusion.com/uploads/images/1862c21e-6ec1-4a34-8c34-6559.jpg
If it is Popcornfx Super Tools Texture emitter you have "Global scale" and a  size feature in the "lifetime" Panel
http://manual.reallusion.com/PopcornFX_Plug_in_for_iClone/ENU/Default.htm#iClone_7/Pro_7.0/29_Plug_in/Popcorn_Particle_VFX/Texture_Emitter/Lifetime.htm%3FTocPath%3DGuides%2520for%2520PopcornFX%2520Super%2520Tools%7CTexture%2520Emitter%7C_____7
johnwarndt52
johnwarndt52
For some reason, no matter how much I scale down the legacy flame (even to zero.) it didn't shrink one bit. Maybe that was
because I'd already attached it to something. But following your suggestions, I shrank down the popcorn fx flame to just the
dimensions I needed.
Thank you!
