Super Bone Editor - Plugin
Posted By The-any-Key 6 Years Ago
The-any-Key
The-any-Key
Posts: 356, Visits: 1.9K
My latest plugin. Super Bone Editor. Select multiple bones and rotate all at the same time. You can also use bezier curve to gradually apply values along the selected bones. Limiter and SUM can also be set. Good when you want a specific angle for one or more bones.
Trial: https://marketplace.reallusion.com/super-bone-editor---trial
Threaded View
Threaded View
Forum Post Super Bone Editor - Plugin By The-any-Key ( 6 Years Ago )
Forum Post This plug-in does feed many iClone users' needs. Great job, Andreas!... By Tony (RL) ( 6 Years Ago )
Forum Post That is pretty cool! :) A grouping feature might be useful, so you... By Rampa ( 6 Years Ago )
Forum Post [quote][b]Rampa (6/13/2019)[/b][hr]That is pretty cool! :) A grouping... By The-any-Key ( 6 Years Ago )
Forum Post WOW ! That looks exactly what I was looking for :cool: :w00t: By vidi ( 6 Years Ago )
Forum Post It looks close to what I have requested recently (specially with added... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (6/14/2019)[/b][hr]It looks close to what I have... By The-any-Key ( 6 Years Ago )
Forum Post Thanks, I was doing it a hurry following text doc. without checking... By 4u2ges ( 6 Years Ago )
Forum Post I have a little problem. The prop I am trying to animate is very long... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (6/15/2019)[/b][hr]I have a little problem. The prop... By The-any-Key ( 6 Years Ago )
Forum Post i have not such a folder openplugin , what do I missing ? By vidi ( 6 Years Ago )
Forum Post [quote][b]vidi (6/15/2019)[/b][hr]i have not such a folder openplugin... By The-any-Key ( 6 Years Ago )
Forum Post [quote]C:\Program Files\Reallusion\iClone 7\Bin64\OpenPlugin[/quote]... By vidi ( 6 Years Ago )
Forum Post The folder is a default folder and was created during the iClone 7.4... By wires ( 6 Years Ago )
Forum Post Hi Vidi, I also do not have the Open Plugin folder in the normal... By rosuckmedia ( 6 Years Ago )
Forum Post [quote][b]vidi (6/15/2019)[/b][hr] [quote]C:\Program... By The-any-Key ( 6 Years Ago )
Forum Post @ The-any key Yesterday I just reinstalled my Iclone 7.41, and I do... By rosuckmedia ( 6 Years Ago )
Forum Post [quote][b]rosuckmedia (6/15/2019)[/b][hr]@ The-any key Yesterday I... By The-any-Key ( 6 Years Ago )
Forum Post @ The -any -Key Loaded a Script Camera Follow and now I have... By rosuckmedia ( 6 Years Ago )
Forum Post [quote][b]rosuckmedia (6/15/2019)[/b][hr] @ The -any -Key Loaded... By The-any-Key ( 6 Years Ago )
Forum Post [quote]Fixed in version 1.2. Expand dynamically for any number of... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (6/15/2019)[/b][hr] [quote]Fixed in version 1.2.... By The-any-Key ( 6 Years Ago )
Forum Post [quote]Fixed in version 1.3. Range, limit and SUM minimum is now... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (6/16/2019)[/b][hr] [quote]Fixed in version 1.3.... By The-any-Key ( 6 Years Ago )
Forum Post [quote][b]The-any-Key (6/16/2019)[/b]In theory you can create a plugin... By 4u2ges ( 6 Years Ago )
Forum Post We will see if future versions of the Python API will be faster. Some... By The-any-Key ( 6 Years Ago )
Forum Post Hopefully yes, a stable API release would be faster than the current... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (6/16/2019)[/b][hr]Hopefully yes, a stable API... By The-any-Key ( 6 Years Ago )
Forum Post [quote]That is just because you are using Schrödinger's cat. That cat... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (6/18/2019)[/b][hr] I have also noticed that if the... By The-any-Key ( 6 Years Ago )
Forum Post Curve a road tutorial that will explain the limit, SUM and curve maker... By The-any-Key ( 6 Years Ago )
Forum Post Awesome that the solution is really simple! Perhaps the plugin can... By Rampa ( 6 Years Ago )
Forum Post [quote][b]Rampa (6/18/2019)[/b][hr]Awesome that the solution is really... By The-any-Key ( 6 Years Ago )
Forum Post Yes, it would override the existed animation. And since there is no... By 4u2ges ( 6 Years Ago )
Forum Post No, the cable was shaped first and then rigged. But I was thinking the... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (6/19/2019)[/b][hr]No, the cable was shaped first and... By The-any-Key ( 6 Years Ago )
Forum Post Cool tool ;) BUT 1. i created groups, but when i select a group... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/25/2019)[/b][hr]Cool tool ;) BUT 1. i... By The-any-Key ( 6 Years Ago )
Forum Post [quote]Currently you can only move bones using local Euler... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (7/25/2019)[/b][hr] [quote]Currently you can only... By The-any-Key ( 6 Years Ago )
Forum Post 4. The keyframes do not appear where they should... Mostely way... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/25/2019)[/b][hr]4. The keyframes do not... By The-any-Key ( 6 Years Ago )
Forum Post I sent the project but it is made in 7.5... By toystorylab ( 6 Years Ago )
Forum Post does this work with characters? By TBone50 ( 6 Years Ago )
Forum Post [quote][b]TBone50 (7/25/2019)[/b][hr]does this work with... By The-any-Key ( 6 Years Ago )
Forum Post Ok, got the groups working ;) By toystorylab ( 6 Years Ago )
Forum Post After a new attempt with a blank project the keyframes get where they... By toystorylab ( 6 Years Ago )
Forum Post Started working further on this and keyframes still don't drop on my... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/26/2019)[/b][hr]Started working further on... By The-any-Key ( 6 Years Ago )
Forum Post [quote][b]The-any-Key (7/27/2019)[/b][hr][quote][b]toystorylab... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/27/2019)[/b][hr][quote][b]The-any-Key... By The-any-Key ( 6 Years Ago )
Forum Post [quote][b]The-any-Key (7/27/2019)[/b][hr]Found the time issue and it... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/28/2019)[/b][hr][quote][b]The-any-Key... By The-any-Key ( 6 Years Ago )
Forum Post [quote][b]The-any-Key (7/28/2019)[/b][hr]So you never got a message... By toystorylab ( 6 Years Ago )
Forum Post Meanwhile i set IC7+CC3+3DX all to "start in admin mode"... (are there... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/29/2019)[/b][hr]Meanwhile i set IC7+CC3+3DX... By The-any-Key ( 6 Years Ago )
Forum Post [quote][b]The-any-Key (7/29/2019)[/b][hr] Did you try the Python... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/29/2019)[/b][hr][quote][b]The-any-Key... By The-any-Key ( 6 Years Ago )
Forum Post After quitting and reopening project, groups must be recreated... I... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/26/2019)[/b][hr]After quitting and reopening... By The-any-Key ( 6 Years Ago )
Forum Post [quote][b]The-any-Key (7/26/2019)[/b][hr] I could add a save and load... By toystorylab ( 6 Years Ago )
Forum Post [quote]Some of the quaternion bugs are fixed. But... By 4u2ges ( 6 Years Ago )
Forum Post I still have no clue why it behaves so strange on my pc, but here is... By toystorylab ( 6 Years Ago )
Forum Post Sorry, it appears... BUT only when i start iClone as administrator. In... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/28/2019)[/b][hr]Sorry, it appears... BUT only... By The-any-Key ( 6 Years Ago )
Forum Post My firt impression ... Oh Boy it is so easy in DAZ studio to grab... By vidi ( 6 Years Ago )
Forum Post [quote]It can not to be so hard to implemented, for select all bone... By 4u2ges ( 6 Years Ago )
Forum Post [quote]That is a question to RL I suppose... and not to the fellow... By vidi ( 6 Years Ago )
Forum Post I got it working . I had to update iclone . It do exactly what I... By vidi ( 6 Years Ago )
Forum Post [quote][b]vidi (7/28/2019)[/b][hr] I got it working . I had to update... By The-any-Key ( 6 Years Ago )
Forum Post New tutorial for the new features:... By The-any-Key ( 6 Years Ago )
Forum Post Yo, nice... My brain didn't get it completely after first sight, but... By toystorylab ( 6 Years Ago )
Forum Post Makes fun ;) Is it possible to allow "rename" group? While creating... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/29/2019)[/b][hr]Makes fun ;) And is it... By The-any-Key ( 6 Years Ago )
Forum Post Oops, altering the speed of an animation seems to make it glitchy...... By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/29/2019)[/b][hr]Oops, altering the speed of... By The-any-Key ( 6 Years Ago )
Forum Post Copy and paste a keyframe not possible?? By toystorylab ( 6 Years Ago )
Forum Post [quote][b]toystorylab (7/29/2019)[/b][hr]Copy and paste a keyframe not... By The-any-Key ( 6 Years Ago )
Forum Post [quote][b]The-any-Key (7/29/2019)[/b][hr] Elaborate[/quote] What does... By toystorylab ( 6 Years Ago )
Forum Post Damn, i just noticed you have a 1.5 out there, that was not clear for... By toystorylab ( 6 Years Ago )
Forum Post Another little Test with SBE... Used with:... By toystorylab ( 6 Years Ago )
Forum Post @toystorylab You are very creative, very good. :D Greeting... By rosuckmedia ( 6 Years Ago )
Forum Post Looks nice... s***t :D By 4u2ges ( 6 Years Ago )
Forum Post Update 1.6: Fix crash when just open plugin and change timeline... By The-any-Key ( 6 Years Ago )
