Render Video File with transparent background /alpha channel
Posted By ultimativity 7 Years Ago
Posts: 23.1K, Visits: 36.6K
utiba.ajeet (10/22/2021)
It doesn't do the transparent image with Sequence Image as well.
Sequence Image PNG will give you a transparent background but you must make sure you don't have a Background active. You can uncheck this in Project Settings (CTRL+SHIFT+P).
utiba.ajeet
utiba.ajeet
New Member (22 reputation)New Member (22 reputation)New Member (22 reputation)New Member (22 reputation)New Member (22 reputation)New Member (22 reputation)New Member (22 reputation)New Member (22 reputation)New Member (22 reputation)
Posts: 5, Visits: 39
richard666
richard666
Posts: 74, Visits: 425
You CAN render witha transparent backround when IRAY rendering.  On the tool bar to the left of the Photoreal box (IRAY section) there is an icon that looks like a 3 in a square box. Hit it and it brings up render settings box. You will see a box you can tick to produce a transparent background
ginger.grant_135173
ginger.grant_135173
New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)
Last Active: 6 Years Ago
Posts: 1, Visits: 2
need to add background options on video bake
Last Active: 3 Weeks Ago
Posts: 15.8K, Visits: 31.4K
ultimativity (6/13/2019)
That's interesting about the sequence quality being superior. I will give the png image sequence a shot. I have to look up how my video editor handles sequences, is all.
The reason most of us prefer image sequences is that PNG is compressed, but lossless. So during editing you will maintain the best quality. and you can then decide how you want to distribute your video, which will necessarily involve lossy compression because of file size.
Most codecs use much higher and lossy compression, which is undesirable, because that will establish early on the best quality you can accomplish for the final product. In addition, video encoded this way is less suitable for editing.
ultimativity
ultimativity
Posts: 356, Visits: 737
I did convert the project background to neon green. My video editor did a nice job of chroma keying, so I also have that option.
Thanks again to everyone for the responses.
Nathan
Does Reallusion plan to add capability to render without background?
Thanks again
We already do with Sequence Image output. I'm not sure why you don't want to use this format but I would advise giving it a try. Almost any video editor will accept Sequence Images and the quality is much better than when using video codecs.
Posts: 8.2K, Visits: 26.5K
Some people put a large GREEN (or blue) plane as their background, and in their video editing software (NLE) they will "Chroma Key" out the green background.  But a better solution is to use a "mask" as was previously mentioned
Iray… Yes, Iray can render with a transparent background, but then again, so can iClone's native renderer... both of them generating a sequence of PNG files, except Iray will take a LOT, lot longer.  Iray can also generate, at minimal additional cost (time), several output channels, including a "mask," a depth channel (good for doing fog or DOF work in your NLE), material ID, object ID, and several other possible channels.  It should enable some very creative post-processing possibilities, but I don't know of any iClone users who've taken proper advantage of them yet (probably due in large part to time required for any Iray animation rendering).
ultimativity
ultimativity
Thanks for your responses. I will check out popVideo.
Can rendering video using iRay accomplish videos with transparent background?
Thanks again
Nathan
The only export formats that support a transparent background are Sequence Image and popVideo. You can also render a separate black and white alpha channel video which can be taken into a video editor, along with the source video, to remove the background that way.
