Hank
Load the sky and under Props > Modify, check the xyz lock and reduce to about 45%. Your sky dome will show up and you can adjust the setting to suit
Shy "O wad some Power the gift tae gie us, to see oursels as ithers see us!"
If I load a world wilderness scene and then add a sunset prop,
it doesn't show up. What's the trick?
It works OK if I load only a character and then the sunset.
Thanks,
