Question on sky pack
https://forum.reallusion.com/Topic4126.aspx
Print Topic | Close Window
By hmadden - 18 Years Ago
How do I use the sky pack with the 3d background pack?
If  I load a world wilderness scene and then add a sunset prop,
it doesn't show up. What's the trick?
It works OK if I load only a character and then the sunset.
Thanks,
Hank
By shygirl - 18 Years Ago
Hi,
Load the sky and under Props > Modify, check the xyz lock and reduce to about 45%.  Your sky dome will show up and you can adjust the setting to suit
Shy
Thanks Shy,that did it.
Hank
