Export to Self Hosting Problem
Posted By Elvis_P 16 Years Ago
catherine_laroche
catherine_laroche
Posted 16 Years Ago
Veteran Member (695 reputation)Veteran Member (695 reputation)Veteran Member (695 reputation)Veteran Member (695 reputation)Veteran Member (695 reputation)Veteran Member (695 reputation)Veteran Member (695 reputation)Veteran Member (695 reputation)Veteran Member (695 reputation)
Last Active: 14 Years Ago
Posts: 26, Visits: 106
Sometimes, when this happens to me, I simply export the widget again, but under a new name. If I post this new version of the widget under its new name, it will work.
Mars24o7
Mars24o7
Posted 16 Years Ago
New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)
Last Active: 8 Years Ago
Posts: 3, Visits: 172
Hey guys,
I have tried everything you said but the results were the same. I uninstalled the program, clear all leftovers, (registries, program data, etc) and reinstalled it!
I don't know what might was the problem but know everything works just fine now!
Thanks for your help! :)
Mars
Mick
Mick
Posted 16 Years Ago
Last Active: 16 Years Ago
Posts: 218, Visits: 588
Hi,
When you expot widget to your self-hosting, you must type the correct hosting URL. After exporting, you will get some files, and then you need to upload all files to your web hosting.
If you do any change in your project, you still need to re-upload the files to your web hosting. After that, you are able to see the change.
You can also refer to the following:
How to show the new widget correctly?
1. Export it as you used to.
2. Paste the new embedded code(from new online.html file) to what you want.
3. Clean the cache of the browser.
Yours sincerely,
Mick
Technical Support
Reallusion Inc.
Mars24o7
Mars24o7
Posted 16 Years Ago
Hi Derek, thanks for replying,
Let me see if i understand correctly...
The online.html is not the file that i am going to use-upload? It's just a code that i will copy and paste on other html file? It says: "<!-- Start to copy from here -->" and "<!-- End until this point -->". Does this have to do with what you are saying?
What if i just want to upload it as a whole, not as a part of a website... (As i mentioned in the previous post i created a kind of a mini website).
I have cleaned up my browser's cache, but still can't preview the new exports... :angry:
Thanks again for trying to help!
derekdai77
derekdai77
Posted 16 Years Ago
Posts: 15, Visits: 27
Hello Elvis and Mars,
did you paste the new embedded code after you export? WidgetCast will generate a embedded code when edit each time.
the steps to show the new project are:
1. export it as you used to.
2. paste the new embedded code(from new online.html file) to what you want.
3. clean the cache of the browser.
it should work :)
enjoy it
Mars24o7
Mars24o7
Posted 16 Years Ago
Hello, i am experiencing the same problem.
I just bought WidgetCast Pro and i created a website sample which i have uploaded to my website. If i make changes to that project the results i get either by just previewing it from the export folder or by uploading to my website is the same as the very first export.
Furthermore, when i create and export a different widget and export it for self hosting it doesn't load at all. It just shows the outline and never loads.
I am using windows 7 64 bit. Maybe this has something to do with my system, for example how it handles the templates or something? I am very desperate because WidgetCast seems like a fantastic piece of software and i can't use it the way i want.
Forgot to mention that i used the trial version but uninstalled it before installing the normal one. Any advice or help will be highly appreciated.
Mars
Elvis_P
Elvis_P
Posted 16 Years Ago
Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)
Last Active: 6 Years Ago
Posts: 1, Visits: 14
I have exported a project using Self Hosting Option. I preview it in my web browser and works great. After that i made some changes in the project, and everytime i try to export it the browser preview appears exactly like the first export.The changes are saved in the project, but the export doesn't show the changes, instead it shows the first export.Please i need to know what causes this problem. I tried restarting the computer, even reinstalling the program.
