woody173
woody173
Visits: 571
Hi I bought a city scape from the market place and have hit a slight snag. The path is higher than the road and therefore my foot contact sinks through the path. I have tried laying an invisible floor on top of the kerb and turning that into a terrain but that doesnt work. is their any way of correcting this or is their a short cut around it so the kerb is treated the same as the road. Thank you Woody
sjonesdc
sjonesdc
Posts: 1.6K,
Visits: 9.6K
woody173 (4/8/2019) Hi I bought a city scape from the market place and have hit a slight snag. The path is higher than the road and therefore my foot contact sinks through the path. I have tried laying an invisible floor on top of the kerb and turning that into a terrain but that doesnt work. is their any way of correcting this or is their a short cut around it so the kerb is treated the same as the road.
Thank you
WoodyWhich city scape? and is the path suppose to be higher than road?
sjonesdc :hehe:
STILL LEARNING!!!
woody173
woody173
Visits: 571
The city scape was the victorian city (EZ Sets Modular Victorian Town) The footpath is slightly raised from the road and their is quite a drop from the path surface to the road surface. but the terrain seems to be only the road surface. As I said i tried to put an invisable floor on top of the path and put that as the terrain so my foot falls on top of the path but its getting a bit fiddly.
Rockoloco666
Rockoloco666
Group: Banned Members
Last Active: 6 Years Ago
Visits: 2.0K
Try selecting the invisible prop and uncheck bounding mesh.another thing to try is tu attach a ddummy object to the path and link your avatar to the dummy that way you can use transformkeys to raise the character manually
Last Active: 10 days ago
Visits: 62.6K
You are likely seeing the foot contact only on the road because it is the lowest part of the set, and right on the grid, which what your character is walking on if you have not specified a different terrain.
If only need characters on the path, and wish to use the grid as the walking surface, you can lower the set so the path is at grid level. It's a cheap workaround if you cannot get both working properly as terrain as Raxel_67 mentioned.
