Setting Facial (Viseme) Keyframe in iClone 7
Posted By mattypattyfp 7 Years Ago
mattypattyfp
mattypattyfp
Veteran Member (636 reputation)Veteran Member (636 reputation)Veteran Member (636 reputation)Veteran Member (636 reputation)Veteran Member (636 reputation)Veteran Member (636 reputation)Veteran Member (636 reputation)Veteran Member (636 reputation)Veteran Member (636 reputation)
Posts: 14, Visits: 76
Hi,
I'm trying to setup a model (CC3) for use with FaceFx.  To do so, I have to set keyframes for the visemes at certain times.  Here's the instructions:
https://facefx.github.io/documentation/doc/default-character-setup
I have two related questions:
1) Is there a way to set key frames using the Lips Editor in iClone (since the lips editor already contains the visemes I need)?  It adds the visemes to the Lips track, but I'm assuming I need them to actually modify the Expression >> Muscle track.
2) How can I set key frames from the tongue?
