Setting Facial (Viseme) Keyframe in iClone 7
Posted By mattypattyfp 5 Years Ago
mattypattyfp
mattypattyfp
Veteran Member (574 reputation)Veteran Member (574 reputation)Veteran Member (574 reputation)Veteran Member (574 reputation)Veteran Member (574 reputation)Veteran Member (574 reputation)Veteran Member (574 reputation)Veteran Member (574 reputation)Veteran Member (574 reputation)
Posts: 14, Visits: 76
Hi,
I'm trying to setup a model (CC3) for use with FaceFx.  To do so, I have to set keyframes for the visemes at certain times.  Here's the instructions:
https://facefx.github.io/documentation/doc/default-character-setup
I have two related questions:
1) Is there a way to set key frames using the Lips Editor in iClone (since the lips editor already contains the visemes I need)?  It adds the visemes to the Lips track, but I'm assuming I need them to actually modify the Expression >> Muscle track.
2) How can I set key frames from the tongue?
Posts: 15.7K, Visits: 30.5K
It surely is an interesting concept.
Recently we had a discussion about how to improve iClone lip-syncing using Papagayo (which also can use a text file to improve the results), but this may be even more convenient.
Tentatively, I believe you can accomplish what you want to do. (Someone smarter may give you an already more definitive response).
I haven't done much with FBX export of facial animation, but as far as I know you should be able to export the viseme track as part of a MotionPlus clip, which includes facial animation.
Animation for the tongue needs to be set up I think (used to be at least). I have to see if that is still possible. There may already be an existing animatable morph for it.
I'm reading that the shapes need to be keyed, but that should still be possible with visemes (perhaps adding None before and after the target viseme). I just don't know how it ends up in the FBX file.
Posts: 9.1K, Visits: 21.8K
I just woke up so I may not quite get all this -- first of all, what the hell is FaceFX?  Is that for export to Unity or some other animation program?
In any case, this seems real straightforward to create a Python program to do this in iClone.  But, again, I may just be asleep and not getting the whole point here (because just a cursory glance at the FaceFX docs indicates there's a Python Import pipeline so I'm not sure where that even is -- import to where?  And if there is, why didn't they write the Python to do the correct setup in iClone?
I may need to wake up more -- or perhaps someone can tell me the bigger picture here.
mattypattyfp
mattypattyfp
Thanks, animagic.
I can setup the base visemes using the Modify tab of the Face Key Editor.  Interestingly, the FV key isn't recognized in FaceFX (I use the Bite Lip slider to set that.)  Then I just do an FBX export directly from iClone.  It'd just be more convenient from the Lips Editor.
I would definitely be interested in a feature that leverages a text file to improve the lip syncing.  I get a better quality output letting FaceFX automatically lip sync , than I do in iClone or CrazyTalk.  Otherwise, I would just stay inside iClone/Crazytalk.  Although FaceFX has some nice features - the big one is that you can place "marks" inside the text file to trigger gestures and animations.
Regarding, "getting the visemes into an FBX" -- I'll try setting them with the Lips Editor exporting the RLTalk file into 3DXchange and exporting that way.  Also I'm wondering if I can set the key frames directly inside 3DXchange -- doesn't it have a lips editor as well?
mattypattyfp
mattypattyfp
Hi Kelleytoons,
I think FaceFX uses the keyframes at specific locations to then animate the lips. So, I'm not sure the python script approach would work.  I don't know how you'd set the morphs in the python code. But I'm very new at this, so I could be missing something here.
The bigger picture here (for me) is to get better quality lipsyncing in less time.  I currently spend a lot of time in iClone - largely because I end up discarding most of the automated visemes and re-doing them.
Okay, I'm more awake now and am starting to get the picture.  You use FaceFX outside of iClone somewhere to generate your sync, and then import.  If you do want to look at my Papagayo route (it might help -- got us lip sync good enough for Fox television) here's the video:
mattypattyfp
mattypattyfp
Thanks guys. This gave me some things to try.  Kelleytoons, I got the script to work for a couple of lip-sync
Dr. Nemesis
Dr. Nemesis
Posts: 258, Visits: 5.4K
Hey matty, I used FaceFx for games back in the day and am now starting to look at using it for Iclone. Please keep us posted with your progress. I won’t activately start work on this yet since I’ll (hopefully) be using it on my next project but I’ll be interested to see your results!
From what I can see FaceFX is the best choice for high quality automatic lip sync so this is fairly important.
