stephenq80
stephenq80
Visits: 96
Hello, Thank you for reading my post. I am using the full version of Character Creator 3 Pipeline version 3.04. I am fairly certain that when I purchased this software that I read that clothing can be imported as OBJ files. And I could have sworn that I seen that at one point. However, I no longer see that as an option. If I try to import anything that I made, it says it has to be .Fbx and I need an Fbx Key. When I chose the create clothing option, it says in parenthesis "with Fbx Key." Fine, ok, no big deal to convert my obj file to Fbx. However, what I cannot figure out for the life of me is where do I get the Fbx key. I have tried exporting just about everything I can think of from the software and nothing spits out an Fbx key. I am making clothing in zbrush and need to get it back into CC3 to try on the character. I have not used the software very much, all I have done in the past is used it to spit out a nude character model that I have been using for practice. If someone can help me get that Fbx Key, that would be super appreciated.
Thank you!
Last Active: 35 minutes ago
Import obj as an accessory, and then change by adding cloth weights to clothing.
5 Years Ago by
Last Active: 10 hours ago
stephenq80
stephenq80
Visits: 96
Thank you very much Kelleytoons and Peter. The information that you two provided helped very much.
