Dorothy Jean
Dorothy Jean
Last Active: 6 days ago
Visits: 1.1K
Hello, I exported an FBX of a character into Blender so I could tweak the face to create a new head. Everything worked great and looked great in CC3 until i went to move the morph slider. The eyes and mouth spin around inside the head and don't get placed where they should at the end unless i go in and tweak the eyes. I did not do anything to the eyes or mouth inside blender only moved facial vertices around and did not change the typology. Can someone tell me how to avoid this? I spend all day making this head and now I don't think I can sell it unless i can find a fix for this. Below is a photo of what the morph slider looks like at 50% Thanks!
Posts: 5.0K,
Visits: 16.0K
I am sure I miss something. But how did you create a morph slider in CC from FBX?
Dorothy Jean
Dorothy Jean
Visits: 1.1K
U just export the fbx character into blender then export it back out and into CC3. Have to use the key file. I got it working but i feel its really a hit or miss so i made small tweaks and just made a bunch of morph sliders for each part of the face then turn them all on and make 1 slider out of all them. Its no ideal. Just need to figure out why this happens randomly
Posts: 5.0K,
Visits: 16.0K
Now I am wondering what is the advantage of using FBX > iAvatar approach as oppose to more straightforward OBJ format for morphs sliders. Given that no app is perfect, more conversions in a way would always be prone to more errors. Just curious.
Dorothy Jean
Dorothy Jean
Visits: 1.1K
U can use obj too. I tried both but still ended up eating my eyeballs. Ha! Does this happen when u use goZ? If not im tempted at getting a subscription....
vidi
Posts: 10.8K,
Visits: 40.2K
Eyes and theeth are seperate parts . When you create morhs you have a offset in the geometry . Therefore Bone need compensare the offset Important you import with the option adjust bones to fit morphs . After that adjust the eyes and theet in the adjust bones tab /face /include eyes and theeth.
5 Years Ago by
vidi
Dorothy Jean
Dorothy Jean
Visits: 1.1K
vidi (3/31/2019)
Eyes and theeth are seperate parts . When you create morhs you have a offset in the geometry . Therefore Bone need compensare the offset Important you import with the option adjust bones to fit morphs . After that adjust the eyes and theet in the adjust bones tab /face /include eyes and theeth. Thank for the info on the adjusting bones tab, i did not know about that. I did check the option "Adjust bones to fit morphs" But that did not prevent my eyes and teeth from spinning around inside my head during the morph transition. Any idea?
vidi
Posts: 10.8K,
Visits: 40.2K
create a Morph Slider from new adjusted Character
Dorothy Jean
Dorothy Jean
Visits: 1.1K
vidi (3/31/2019) create a Morph Slider from new adjusted Character I tried that too and the same thing happend. I have spend all weekend trying to get this to work and have tried so many things because the face I made turned out sooo well. I would hate to have to start over. guh.
vidi
Posts: 10.8K,
Visits: 40.2K
For me it work
