Rogue Anime
Rogue Anime
Visits: 3.4K
Friends - Thanks to everyone for being so present, thoughtful & knowledgeable! Can someone direct me to a tutorial that will show me how to create an iProp from an existing .PNG logo? I have Photoshop & related Adobe products. Thanks a bunch ~V~
Val RogueAnanda
Visits: 22.1K
Val, I guess it would depend on what you are looking for -- do you mean you want to take a PNG file and just overlay it on a rectangle, or are you looking for some bas-relief (if the latter you are probably talking about using the Substance Bitmap to Material, which you'd have to have).
Last Active: 5 Months Ago
Posts: 15.8K,
Visits: 31.4K
Like Mike suggests. The opacity channel of the PNG file makes the parts of the rectangle that supposed to be invisible transparent. I have used it to create a neon sign and it works quite well.
Visits: 62.6K
Do you mean actual 3D lettering? You would need to that externally and import it.
Visits: 22.1K
Or, as I said, if you just want bas-relief use the Substance tool for it:
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
So, as far as a 'tutorial', I guess Mike is referring to something like this:
Please be patient with me ..... I don't always 'get it' the first time 'round - not even the 2nd time! :( - yikes! ... ● MSI GT72VR Laptop, i7 7700HQ 4-Core 3.8 GHz 16GB RAM; Nvidia 1070, 8GB Vram ● iClone-7.93 ● 3DXChange Pipeline 7.81 ● CC-3 Pipeline 3.44 ● Live Face ● HeadShot ● Brekel Pro-Body ● Popcorn FX ● iRAY ● Kinect V2 ● DaVinci Resolve17 ● Mixcraft 8.1
illusionLAB
illusionLAB
Visits: 4.8K
You can do it right in Photoshop. A better way would be to 'trace' the PNG in Adobe Illustrator and export an SVG spline which you can extrude in Blender. If you have the full Adobe Cloud Suite, you also have Cinema 4D Lite - so you can export a 'trace' from AE to C4D to extrude. https://www.youtube.com/watch?v=rRdoBRR8V40
Visits: 22.1K
I keep forgetting I have C4D lite -- I should boot it up some time and take a look at it (I looked at it many years ago, but perhaps it would work as a tool for me at times). Thanks for reminding me.
Rogue Anime
Rogue Anime
Visits: 3.4K
WOW! All these wonderful responses! Thanks to Mike, Steve, Rampa & Dennis - I Mayhaps should have been a bit more specific! The end result of what I need to achieve would be to have the original PNG transformed into a 3D prop such as the one displayed here. Sorry for the confusion friends ~V~
Val RogueAnanda
mark
Posts: 4.9K,
Visits: 16.7K
As Mark said, that is easy in Photoshop. If you have CS6 extended on up you can create a nice 3d object from a .png with it. I did this rough test just the other day with this guy's signature, made a .png in Photoshop then converted it to an .obj, then brought it into iC7
