planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
Do the features on Windows 10 pro for workstations have a direct impact on the performance of RL products / CG in general. ? it seems like it should, but anything significant that's worth 100 bucks more than the basic pro version ? Best for advanced users and small businesses that want enhanced functionality with the ability to compute intensive workloads. All of the features of Windows 10 Pro plus: -Resilient File System (ReFS) designed for high fault tolerance and handling large data volumes -Persistent memory to access files fast - at the speed of your computer’s main memoryFaster file sharing with features that offer increased throughput with low latency and low CPU utilization -Ability to run high performance device configurations with expanded hardware support
5 Years Ago by
planetstardragon
mark
Last Active: 8 hours ago
Posts: 4.8K,
Visits: 16.5K
...and hopefully full and easy control of Microsoft updates?????
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
Hi Mark yes exactly, that's actually how I found out about this version, I was pricing out the pro version because I know it controls updates and discovered the relatively new pro workstations - which has all the pro features ...and is actually considered an add on to windows ..... It just came out April 2018 .... it's supposedly the newest iteration of windows 10 - which I hope microsoft doesn't start getting into stuff like Windows 10 Red, green, or blue versions because it would really confuse the kittens out of everything. Microsoft is not doing a great job with advertising stuff, I'm sure this new w10 version would be a big deal to many people from the digital arts industries that have been holding on to 7 - I know i held on to 7 after the horror stories of incompatibilities, wiped drives and privacy invasions. Oh, one more feature I discovered after I posted this, It can go upto 6 tb of ram!! Texture THAT!
5 Years Ago by
planetstardragon
Posts: 15.7K,
Visits: 30.6K
I wasn't aware of this version. I have been using the regular Windows Pro, and it also allows you sufficient control over updates (as opposed to Home) and unexpected reboots. There is already an update track for businesses (now called Semi-Annual Channel), which delays updates sufficiently that most problems have ironed out. You can also defer updates further if you want, which is what I do. So unless you need the new file system and other features, Pro would be sufficient for most. However, anyone reading this, NEVER get Home.
mark
Posts: 4.8K,
Visits: 16.5K
It all sounds pretty good, as I will have to be movin' to 10 pretty soon!
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
same, the 6 tb ram limit, update-control and os stability actually made it something to look forward to, i was dreading updating after all the problems home users were going through when windows 10 first came out.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
animagic (2/20/2019) However, anyone reading this, NEVER get Home. Hi Job, can you detail the reasons ? Roberto
Posts: 15.7K,
Visits: 30.6K
RobertoColombo (2/22/2019)
animagic (2/20/2019) However, anyone reading this, NEVER get Home. can you detail the reasons ? The main reason is that the Home version gives you very little control over Windows updates. There has been quite a number of instances where those updates caused problems just after their release, forcing Microsoft to postpone those updates, meanwhile leaving the users with sometimes unusable machines, lost files, etc. Another issue, that is now partially addressed, is that Windows would reboot without the user having any option of being able to postpone the reboot. Imagine doing an Iray render and your system decides to reboot. The Pro version gives you far more options. The most useful one is that you can opt to go on the slow update track as far as features are concerned, so you are usually six months behind (updates come every six months). During that half year you may hope that most update problems have been resolved. You can also set Active Hours, where Windows won't bother you, but I think Home is that option as well now. With Pro you also have more control over the OS, using the Group Policy Editor for example, which is missing in Home.This is more for power users, though.
Last Active: 12 hours ago
Posts: 5.7K,
Visits: 26.4K
Another advantage of the Pro version is that the user can block any, and all, driver updates. This means that if you have a good running system with software requiring a specific driver version for any installed hardware then said driver(s) will not be automatically updated by windows ensuring that things don't get messed up just because NVidia released a driver version to work with the latest version of "Martian killer tomatoes"
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Thanks Gerry and Job
In fact I am setting up a "lower end" system (GPU GTX980 4GB, CPU i7-4x, 16GB RAM) aimed mostly at Python development, whereas the main "beast" is for iClone 3D Animation. For the lower I planned to use Windows 10 Home. I hope the automatic updates won´t be an issue, considering the target usage of the low-end PC.
Cheers
Roberto
