The Iray search for the "Sweet Spot" render settings ...
Posted By sonic7 6 Years Ago
sonic7
sonic7
Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)
Posts: 1.7K, Visits: 19.4K
Greetings to all - this thread is mainly for the "indie film makers" ....
As a result of the recent release of Iray for iClone, there's no doubt been a lot of "testing" going on...
I don't pretend to have the "perfect" answer here, but thought I'd share my findings anyway ....
I run a single Nvidia GTX-1070 card, (probably currently 'middle-ish' in the overall mix of graphics cards out-there).
OK. - so like everyone else, I wanted MAXIMUM quality for MINIMAL "hit" on my PC (laptop actually).
So here it is ... maybe give it a try ... it's designed for MAX speed ... (compromises of course!).
SETTINGS:
● De-Noise set to "39"
● Eliminate Shadow Artifact "ON"
● Anti-Alias Radius "1.5"
● Hardware Settings - Threads = "6" (depends on your particular PC)
● Render Mode "Interactive"
● GI Mode = "Diffuse" (problems can occur if using "Diffuse + Specular")
● Raytrace Quality = "High"
● Preview Auto Update = "ON"
● Preview Tessellations and Displacements = "OFF"
● Frame Size = "Custom" (I use 960 x 409).
Under "Export Settings"
● Select a folder location and your output Format (I used PNG).
● Export Mode = Standalone Render (Save MI Scene) - which is the 'default' setting.
●  Output Size = 1920 x 1080, OR, if needing widescreen, try 1920 x 818 (for a 2.35:1 aspect ratio) (or 1920 x 800 for a 21:9 aspect)
● Enter your 'Range' to be rendered.
● Frame Rate = 24 (or as you require)..
● Stop Criteria - Sample Iterations = "40" (that's right start at just "40" iterations! - you can always increase if needed) :)
PLUS, under iClone's 'Edit' > 'Preferences' > 'Iray Render Globals', you could reduce the 'Max Texture Size' to 1024 x1024
● Set your Viewing Quality to iClone's new "Minimal" setting (if you're running a bit low on VRam).
After hitting "render" It takes several minutes for the full 'loading' to occur, and then the frames will render sequentially after that.
You might be surprised how *fast* your render will be,. These 'lean' settings yielded me 3 frames per minute on my sample scene.
Also, given that these settings are for "Interactive Mode" (rather than "Photoreal Mode"), you might need to add some "Temporal Filtering" to smooth any slight 'flicker' or 'fluctuations' within the finished render sequence. - You could run your exported png sequence through a 'non linear editor' like Vegas (or similar), adding a 'temporal filter'. I used the 'Boris Temporal Blur' with it's 'default' setting. (Somebody might suggest something better though?). Edit: Just discovered that Boris 'BBC Noise Reduction' does a better job - it has a preset called 'Suppress More Y Noise' which seems to work well. (But dial the 'sharpness' to 0). Also maybe use 'BBC Gaussian Blur' with the preset 'slight blur.bsp' and dial the (linked) horizontal/vertical value to 0.5
The only other thing done in Vegas were the 'Levels'. For that I simply used 'Vegas Levels' to boost the overall gain and set the black levels. The 'order' of the filter chain was ● Levels > ● BCC Noise Reduction > ● BCC Gaussian Blur.
Edit: OK - here's an even better result:
* Vegas 'Levels' to set Gain, Gamma & Black level.
* 'BCC Flicker Fixer' using the preset 'Default Temporal Smooth YCC' and set 'smoothing' to '3' and 'Y Range' to '3'.
* Finally, 'BCC Gaussian Blur' if you want more of a 'film look'. Use 'Default.bsp' with 'Blur' set to 0.1 (or 0.2 or 0.3 for a 'softer' result).
So the above settings are simply a beginning. Those with older graphics cards may find these settings an advantage, while those with more powerful cards could 'up the ante' and increase the quality settings for sure ... Anyway - I hope this is useful to some as a "starting point".
And of course, if you can offer suggestions/improvements - please chime-in !!!!
Please be patient with me ..... I don't always 'get it' the first time 'round - not even the 2nd time! :(  - yikes! ...
MSI GT72VR Laptop, i7 7700HQ 4-Core 3.8 GHz 16GB RAM; Nvidia 1070, 8GB Vram iClone-7.93  3DXChange Pipeline 7.81  CC-3 Pipeline 3.44  Live Face  HeadShot  Brekel Pro-Body  Popcorn FX  iRAY  Kinect V2  DaVinci Resolve17  Mixcraft 8.1
Threaded View
Threaded View
Forum Post The Iray search for the "Sweet Spot" render settings ... By sonic7 ( 6 Years Ago )
Forum Post thank you Sonic. I've tried your setting and indeed faster . Thank... By charly Rama ( 6 Years Ago )
Forum Post Thanks Charly ... yes I'm yet to venture into using LUTS, GI ans IBL... By sonic7 ( 6 Years Ago )
Forum Post Hi Steve while those are generally some good "optimization"... By AutoDidact ( 6 Years Ago )
Forum Post Hi Auto ... I probably should have said 'basic' indie filmakers -... By sonic7 ( 6 Years Ago )
Forum Post Thanks...even though i let alone the idea of iray animation for now, i... By 3dtester ( 6 Years Ago )
Forum Post I have found LUT filters I can apply in Vegas, so that gives me some... By animagic ( 6 Years Ago )
Forum Post Thanks Job .... yes 40 iterations is extremely 'lean' (was pushing... By sonic7 ( 6 Years Ago )
Forum Post Imagine this as an episode of "In Search Of" with Leonard Nimoy. By TonyDPrime ( 6 Years Ago )
Forum Post .... lol Tony .... By sonic7 ( 6 Years Ago )
Forum Post Although number of required samples would highly depend on the scene... By 4u2ges ( 6 Years Ago )
Forum Post 4u2ges, thanks for the Firefly Filter tip. I was looking for a way to... By animagic ( 6 Years Ago )
Forum Post Thanks Ani for additional tip with Notepad++. I was too lazy to add... By 4u2ges ( 6 Years Ago )
Forum Post @4u2ges ... Looking forward to viewing your pics full screen this... By sonic7 ( 6 Years Ago )
Forum Post Thanks Steve for posting this! I've been playing around with Iray... By Snarp Farkle ( 6 Years Ago )
Forum Post Thanks Snarpe for your thoughts here .... and yes - I too find myself... By sonic7 ( 6 Years Ago )
Forum Post Well here's a test I knocked up for the Loft Scene ... It was done... By sonic7 ( 6 Years Ago )
Forum Post Good Steeve, good. And the render time was...? By charly Rama ( 6 Years Ago )
Forum Post [quote]If that could be eliminated, it would make for incredibly... By 4u2ges ( 6 Years Ago )
Forum Post @4u2ges .... I get what you're saying: it will never be perfect, but... By sonic7 ( 6 Years Ago )
Forum Post Flickering that looks like a 'lighting' problem is usually caused by... By illusionLAB ( 6 Years Ago )
Forum Post Yes Mark - well these are the sorts of things that only the more... By sonic7 ( 6 Years Ago )
Forum Post [quote] I'm *thinking* that static shots may behave better[/quote]... By illusionLAB ( 6 Years Ago )
Forum Post edited (corrected)... @Mark ... Good analogy - even I can understand... By sonic7 ( 6 Years Ago )
Forum Post @Sonic - that looks really good! By TonyDPrime ( 6 Years Ago )
Forum Post Yep, great work at 40. By jarretttowe ( 6 Years Ago )
Forum Post Sorry if this is a noob question. What is the MI format? I usually do... By jason.delatorre ( 6 Years Ago )
Forum Post Good question Jason. I'm not really up to speed on them myself, other... By sonic7 ( 6 Years Ago )
Forum Post " What is an MI file? " Short answer = It is an Iray data file... By justaviking ( 6 Years Ago )
Forum Post It took some digging to find out what "mi" actually stands for and it... By animagic ( 6 Years Ago )
Forum Post i bought iclone iray with lots of expectations for a high quality... By vfxsampath ( 5 Years Ago )
