Changing the background color of a widget
Posted By RobertoColombo 6 Years Ago
RobertoColombo
RobertoColombo
Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)
Posts: 1.6K, Visits: 3.0K
HI,
I am trying, with no luck, to change teh background color of a widget.
The code apparenly should be easy: for example, here given I create a label and try to set the background to RED, but nothing happens.
Basically I am following the method described here: https://wiki.qt.io/How_to_Change_the_Background_Color_of_QWidget
I tried also with QPalette.Background for setColor() (this value is anyway considered obsolete in QT doc) but still no change in color.
import PySide2, RLPy
from PySide2 import *
from PySide2.shiboken2 import wrapInstance
#-- Make a global variable contain dialog --#
sample_dialog = None
def run_script():
    global sample_dialog
    sample_dialog = RLPy.RUi.CreateRDialog()
    sample_dialog.SetWindowTitle("Sample Dialog")
    #-- Create Pyside layout for RDialog --#
    pyside_dialog = wrapInstance(int(sample_dialog.GetWindow()), PySide2.QtWidgets.QDialog)
    pyside_dialog.setFixedWidth(200)
    sample_layout = pyside_dialog.layout()
    #-- Create the Label --#
    label = PySide2.QtWidgets.QLabel("Test")
    #-- Set the widget color --#
    pal = PySide2.QtGui.QPalette()
    color_red = PySide2.QtGui.QColor('red')
    label.setAutoFillBackground(True)
    pal.setColor(PySide2.QtGui.QPalette.Window, color_red)
    label.setPalette(pal)
    #-- Add Label --#
    sample_layout.addWidget(label)
    sample_dialog.Show()
Any ideas ?
Thanks
  Roberto
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO + 1x2TB Samsung
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the MOTU M4 I/F) / DirectX: 12
RobertoColombo
RobertoColombo
Solved!
It works if the style sheet is used rather than a QPalette.
This code makes its job (RGB values are just an example):
def run_script():
    col = PySide2.QtGui.QColor(111, 100, 8)
    label.setStyleSheet("QWidget { background-color: %s }" % col.name())
    #-- Add Label --#
My PC:
SeanMac
SeanMac
Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)
Posts: 416, Visits: 3.4K
That is a fast answer to your problem, Roberto.
I hope you will thank Roberto very much for his assistance;-)
