Changing the background color of a widget
https://forum.reallusion.com/Topic403624.aspx
Print Topic | Close Window
By RobertoColombo - 6 Years Ago
HI,
I am trying, with no luck, to change teh background color of a widget.
The code apparenly should be easy: for example, here given I create a label and try to set the background to RED, but nothing happens.
Basically I am following the method described here: https://wiki.qt.io/How_to_Change_the_Background_Color_of_QWidget
I tried also with QPalette.Background for setColor() (this value is anyway considered obsolete in QT doc) but still no change in color.
import PySide2, RLPy
from PySide2 import *
from PySide2.shiboken2 import wrapInstance
#-- Make a global variable contain dialog --#
sample_dialog = None
def run_script():
    global sample_dialog
    sample_dialog = RLPy.RUi.CreateRDialog()
    sample_dialog.SetWindowTitle("Sample Dialog")
    #-- Create Pyside layout for RDialog --#
    pyside_dialog = wrapInstance(int(sample_dialog.GetWindow()), PySide2.QtWidgets.QDialog)
    pyside_dialog.setFixedWidth(200)
    sample_layout = pyside_dialog.layout()
    #-- Create the Label --#
    label = PySide2.QtWidgets.QLabel("Test")
    #-- Set the widget color --#
    pal = PySide2.QtGui.QPalette()
    color_red = PySide2.QtGui.QColor('red')
    label.setAutoFillBackground(True)
    pal.setColor(PySide2.QtGui.QPalette.Window, color_red)
    label.setPalette(pal)
    #-- Add Label --#
    sample_layout.addWidget(label)
    sample_dialog.Show()
Any ideas ?
Thanks
  Roberto
Solved!
It works if the style sheet is used rather than a QPalette.
This code makes its job (RGB values are just an example):
def run_script():
    col = PySide2.QtGui.QColor(111, 100, 8)
    label.setStyleSheet("QWidget { background-color: %s }" % col.name())
    #-- Add Label --#
By SeanMac - 6 Years Ago
That is a fast answer to your problem, Roberto.
I hope you will thank Roberto very much for his assistance;-)
