Visits: 22.1K
Just hold down the right mouse button and rotate the screen around (you use the left mouse button to move, right to rotate).
joemoretti
joemoretti
Last Active: 6 Years Ago
Visits: 113
all of these postings are REALLY helpful thank you.
ANOTHER QUESTION - when I connect my PN to AXIS the Avatar on screen is always pointing away from me. In the PN YouTUbe clips the avatar is facing -I've looked for a setting in AXIS to rotate the character (its easy in iClone) -
Have I missed something ? Is there something wrong with my setting up?
J
mtakerkart
mtakerkart
Last Active: 4 days ago
Posts: 3.2K,
Visits: 29.2K
I buy this one but it's in canada. I use this for very low temperature outside. But it's very thin and comfordable. I keep only a t-shirt and my boxer-short. https://www.sportsexperts.ca/en-CA/p-vblsuitj-junior-baselayer-suit/506663/506663-2
Visits: 22.1K
Exactly what kind of sports suit is that? I tried Amazon and can find a sort of rubbery vest designed to sweat in, which doesn't strike me as what I want <g>. If I could find out what your sports suit was designed for maybe I can find a similar vest.
Visits: 22.1K
It's an interesting idea. I don't mind putting the arms and leg pieces on, but I really hate putting on that torso piece. Maybe I could get some sort of rubbery vest and do the same thing with it. Thanks for sharing.
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Visits: 22.1K
Mr. M, Thanks for posting. I really need to try this once. When you stay the PN was "attached" to a sports suit do you mean you somehow got it to stick on the suit itself? (so all you had to do was just put the suit on? My biggest issue with the PN is the damn upper torso piece -- putting that on is a bit like trying to wrap cellophane around me.
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
If this can helps you , this is what I made with the Neuron suit and the Iphone X. You can notice that I attach the Neuron on a sport suit :
I use both mouvements : Neuron and canned motions for move I can't make , high jump , backflip , martial fight , etc...
You can see here a mix of my own movement with canned move comming from UDK matinee and some ragdoll from Iclone store.
jamie3d
jamie3d
Last Active: 3 Weeks Ago
Visits: 195
You should check positioning on the arm and thumb - the PN youtube channel has some pretty decent tutorials. check environment for any obvious interference. As Mike mentioned the bands are marked specifically for left and right side, I've messed this up before and accidentally put the left strap on my right arm.
joemoretti
joemoretti
Visits: 113
Thanks again for your help.
J
