The-any-Key
The-any-Key
Visits: 1.9K
Thanks. But I already tested that. And it seem the values returned from the WorldTransform are wrong (filed a bug ticket) Ex if I have a prop or bone with Euler rotation [90,0,0] (x,y,z) with no parent I should get the quaternion [0.707,0,0,0.707] (x,y,z,w). But I get [0.85,0,0,0.53] aka [116,0,0] (x,y,z)
AllenLee (RL)
AllenLee (RL)
Visits: 541
Hi The-any-Key, You can use the "RINode.WorldTransform()" API to get bone's world quaternions. This API is already in the latest development version (2/1/2019). ------------------------------------------------------------------------------------------------------------- You can try this code: import RLPy avatar_list = RLPy.RScene.GetAvatars() avatar = avatar_list[0] bone_compoment = avatar.GetSkeletonComponent() skin_bones = bone_compoment.GetSkinBones() for bone in skin_bones: world_transform = bone.WorldTransform() world_q = world_transform.R() print( world_q.X() ) print( world_q.Y() ) print( world_q.Z() ) print( world_q.W() )
Allen
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Yeah... i confused you with another member :P I will call you TAK (The Any Key) ...
Cheers
Roberto
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Cheers
Roberto
The-any-Key
The-any-Key
Visits: 1.9K
Jeff? (maybe this is a meme or language thing like Jack?)
I am learning quaternions via internet. A good way to experiment with them is to use Unity as they are heavily integrated. Never mind the latest question about world space. It seem you can get the world space quaternion by multiply all local quaternions from root to the local object. Ex: root quaternion*hips rotation*spine quaternion... So no update is needed it seems :-)
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Hi Jeff,
I can't help on this because I have no experience on quaternion and Euler angles (even though I suppose soon or later i will have to dig a bit into them...). Sorry.
Roberto
The-any-Key
The-any-Key
Visits: 1.9K
Was able to figure out the maths. But seem the API only allow to get the local quaternion rotation. The world transform get return wrong values. So I need to wait until they update the API.
The-any-Key
The-any-Key
Visits: 1.9K
Hmm. Trying to link bones from Unity to iClone. It seem the orientation of the axis is different when export to Unity. So I need a way to translate it. But my math skills is not that good when it comes to matrix and quaternions math. We will see if the people at Unity forum can help. https://forum.unity.com/threads/calc-local-rotation-with-local-axes-based-on-first-parent-local-rotation.619480/
Do anyone have an idea what I can send instead of the euler or quaternions to make the same rotation in Unity as iClone. I can use the world angles. But the problem with tthat is that the world angles is affected by other bones and I would need to "local" world angles.
SeanMac
SeanMac
Visits: 3.4K
Hi Tak
Thanks for that.
"But the goal is to make it generic so I canadapt it to connect to mostly anything that support sockets. "
Very much approve - proper middleware programming.
More power to your elbow! SeanMac
The-any-Key
The-any-Key
Visits: 1.9K
Why I use Unity is because the sample used Unity. I have never used Unity before, so I can't comment on how their manners as humans are (it's a cooperation, what do you expect :-). But it seem Unity have a bunch of plugins that can create interesting animations. Ex I want to try Puppetmaster and sync it to iClone: https://assetstore.unity.com/packages/tools/physics/puppetmaster-48977But the goal is to make it generic so I can adapt it to connect to mostly anything that support sockets. About joysticks: I actually have a plan to use WiiMote controllers for prop movements. Ex you can duct tape a wiimote to a box or something and move it around. And sync the movement back to iClone. But I have no idea about the quality of the data from the wiimote. So we will see what happens.
