[CC3 to Unreal] Auto-Setup Plugin Download & Update History
Posted By Miranda (RL) 6 Years Ago
Rated 3.3 stars based on 3 votes.
Miranda (RL)
Miranda (RL)
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
You can download the plugin "Character Creator & iClone Auto Setup" from HERE
  • From v1.01, Unreal users can install (copy) the plug-in under the project folder only.  Installing the plug-in in engine-level is no longer supported.
  • The file format is changed from .zip to .exe.  You get the same folders after executing the installation file, and copy the folders for auto setup.
  • Once you update Character Creator to 3.1, and update iClone to 7.6 or any version above, an update notice will prompt upon program startup if there is a new release of the auto-setup tool.
Official 1.22 (Aug 31, 2021) - Compatible with CC3.43, iClone 7.92, Unreal Live Link Plug-in 1.31 for iClone
  • Added: Compatible with Unreal Engine 4.27.
Official 1.21 (Aug 26, 2021) - Compatible with CC3.43, iClone 7.92, Unreal Live Link Plug-in 1.3 for iClone
  • Added: Compatible with ActorCore characters: actorSCAN, actorBUILD. -- Know More
Official 1.2 (March 24, 2021) - Compatible with CC3.4, iClone 7.9, Unreal Live Link Plug-in 1.3 for iClone
  • Added: Now supports Smart Hair system with new hairs, eyebrows, beards, and hair shaders (Auto Setup Required). -- Know More
  • Fixed: Unreal Live link will fail if a special character exists within the node names of a character's skeleton. (FT #7480, reported by kwittykat23)
Official 1.11 (Dec. 28th, 2020) - Compatible with CC3.3, iClone 7.8, Unreal Live Link Plug-in 1.22 for iClone
  • Added: Compatible with Unreal Engine 4.26.
Official 1.1 (July 23rd, 2020) - Compatible with CC3.3, iClone 7.8, Unreal Live Link Plug-in 1.2 for iClone
  • Added: Support for CC3 Base+ characters.
  • Added: iC / CC and UE Shader Mapping: iC/CC Digital Human Shader and SSS shader visual effects are sent to UE and remade inside UE. >> Know More
  • Added: iC / CC and UE Physics Mapping: Character, accessory, props, soft-cloth, and collision shape settings are sent to UE and data is then mapped.
  • Enhanced: Shortened the texture names and file paths (by removing " pbr / tra / Transparency ") to conform with Windows API limitation of 256 characters.
  • Enhanced: Shortened AutoSetup Material file path (changed "Material_instances" to "Materials").
  • Fixed: Only the Standard shader is kept on the character when it is brought into Unreal, even when LW or HQ profile is select. (FT #6604FT #6665)
Official 1.04 (June 8th, 2020) - Compatible with CC3.2, iClone 7.7, Unreal Live Link Plug-in 1.12 for iClone
  • Added: Compatible with Unreal Engine 4.25.
Official 1.03 (Jan 13th, 2020) - Compatible with CC3.2, iClone 7.7, Unreal Live Link Plug-in for iClone 1.11
  • Added: Compatible with Unreal Engine 4.24.
Official 1.02 (Oct 28th, 2019) - Compatible with CC3.1, iClone 7.6, Unreal Live Link Plug-in for iClone 1.1
  • Added: Compatible with Unreal Engine 4.23.
  • Fixed: Auto Setup for Unreal imported dialog (FBX) did not correctly display in 4K resolution. (FT #6224)
  • Fixed: Auto Setup had no buttons to Accept/Change Shader. (FT #6201)
Official 1.01 (Aug. 29th, 2019) - Compatible with CC3.1, iClone 7.6, Unreal Live Link Plug-in for iClone 1.1
  • Added: Adjusted linkages for the new Epic Skeleton IK bone settings that accompany the CC Unreal preset.
  • Added: Shader assignment and UE4 skeleton mapping on characters exported from iClone is now automated.
  • Added: Shader assignment on props exported from iClone is now automated.
  • Enhanced: Linked textures in CC do not associate correctly when exported to Unreal Engine.  A Json file is provided to fix this inconsistency and apply the textures correctly onto the material.
  • Enhanced: LODs are now placed within the same FBX file and will automatically be configured by the plugin when loaded.  The FBX file must be prepared with a special LOD group format.
  • Enhanced: Structural change for Reallusion Unreal Light Weight, High Quality, and Standard shaders.  This updated structure now supports diffuse color, tiling, strength, offset, opacity, and two sided.
  • Fixed: When the sampler type is set to linear color during node creation, instead of using greyscale, the TGA image file becomes indexed color causing a read error.
Beta 2.1 (May 6th, 2019) - Compatible with CC3.04 or above
  • Enhanced: Add mask on LW Shader and HQ Shader as the workaround of tessellation issue. (see details HERE)
Beta 2.0 (April 9th, 2019) - Compatible with CC3.04 or above Beta 2.0 (March 15th, 2019) - Compatible with CC3.04 or above
  • Enhanced: Simplified script execution procedure -- please find this post for detailed instructions
    • You can simply drag and drop a FBX file and the rest of the procedure will be automated.
    • You can now use the Import Button to bring FBX files into Unreal.
  • Added: Customized Unreal Digital Humans shaders for hair, eyes, tongue, teeth, and skin.  The skin will come with two shaders:
    • HQ skin shader (high quality): using Unreal Digital Human as a base, we adjust the settings to up the ante on visual quality.
    • LW skin shader (lightweight): based on the shaders from Epic Game's Paragon, we leverage their highly optimize skin shader without compromising visual quality.
  • Added: Automatically split ORM textures into separate channel assignments for AO, Roughness, and Metallic.
  • Added: Assign the equivalent UE materials based on what was deployed in CC3:
    • Traditional -> Specular
    • PBR -> Roughness & Metallic
  • Fixed: Skeleton meshes for Motionplus will now be re-imported.
Beta 1.1 (Jan. 22nd, 2019)
  • Enhanced: add source of plugin for running C++ projects >> related issue
Beta 1.0 (Jan. 15th, 2019)
  • Initial version
Special Notice & FAQ
Some special notice & FAQ have been mentioned in the tutorials. We collect some important messages, please read it before starting the auto-setup process:
Welcome to share your experience with us, thank you :)
Threaded View
Threaded View
Forum Post [CC3 to Unreal] Auto-Setup Plugin Download & Update History By Miranda (RL) ( 6 Years Ago )
Forum Post a good quality of life future improviment for this plugin and in... By Ellessarr ( 6 Years Ago )
Forum Post [quote][b]Ellessarr (1/15/2019)[/b][hr]a good quality of life future... By Miranda (RL) ( 6 Years Ago )
Forum Post Thanks for the plugin! I'm really looking forward to adding a mix... By artjonessss ( 6 Years Ago )
Forum Post Tested it and the materials all very look good and it saves a a lot... By rogyru ( 6 Years Ago )
Forum Post [quote][b]rogyru (1/15/2019)[/b][hr]Tested it and the materials all... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (1/16/2019)[/b][hr][quote][b]rogyru... By rogyru ( 6 Years Ago )
Forum Post This is an incredible time-saver. Thanks RL for providing this! By sqeezigames ( 6 Years Ago )
Forum Post Will the plug-in be added to the Marketplace UE4? This would greatly... By artjonessss ( 6 Years Ago )
Forum Post [quote][b]artjonessss (1/17/2019)[/b][hr] Will the plug-in be added to... By Peter (RL) ( 6 Years Ago )
Forum Post Hi everyone, The tutorial of " Setting up LOD for CC3 Characters in... By Miranda (RL) ( 6 Years Ago )
Forum Post Done a test inside of Unreal , used standard CC3 char and motion from... By rogyru ( 6 Years Ago )
Forum Post Tried importing several different ways and bringing folder (tried the... By TonyDPrime ( 6 Years Ago )
Forum Post Hi rogyru, Looks nice! (expect for the missing eyelashes :P We'd like... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (1/22/2019)[/b][hr]Hi rogyru, Looks nice!... By rogyru ( 6 Years Ago )
Forum Post Will something like the LOD script be available to use within Iclone... By LookingGlassGraphics ( 6 Years Ago )
Forum Post [quote][b]LookingGlassGraphics (1/24/2019)[/b][hr]Will something like... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi! First of all - what a great idea! Second: would You be so kind and... By macsklad ( 6 Years Ago )
Forum Post Is there any special setup for the hair texture? Opacity and specular... By schmigel.sign ( 6 Years Ago )
Forum Post Hi schmigel.sign, May I know if you were using the Auto-Setup Plugin... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]macsklad (1/25/2019)[/b][hr]Hi! First of all - what a great... By Miranda (RL) ( 6 Years Ago )
Forum Post Thank You, I'm sure there would be more people concerned about this,... By macsklad ( 6 Years Ago )
Forum Post i've found a annoying bug, which could not be precise from the pluging... By Ellessarr ( 6 Years Ago )
Forum Post [quote][b]Ellessarr (2/1/2019)[/b][hr]i've found a annoying bug, which... By Miranda (RL) ( 6 Years Ago )
Forum Post i have another question i'm seeying "too much textures" in my fodder,... By Ellessarr ( 6 Years Ago )
Forum Post Hello, I would like to test the animated character, is there any... By antonio_112635 ( 6 Years Ago )
Forum Post [quote][b]antonio_112635 (2/12/2019)[/b][hr]Hello, I would like to... By Miranda (RL) ( 6 Years Ago )
Forum Post any news about when the fix for the tga and others extensions export... By Ellessarr ( 6 Years Ago )
Forum Post Where can I download the open_A_UE4 pose from??? By har355 ( 6 Years Ago )
Forum Post [quote][b]har355 (2/24/2019)[/b][hr]Where can I download the... By Peter (RL) ( 6 Years Ago )
Forum Post Kia ora I tried the export import but I think I broke it slecting the... By Kiwi-Hawk ( 6 Years Ago )
Forum Post Hello, I'm getting the following error when trying to load my project... By Piepants ( 6 Years Ago )
Forum Post [quote][b]Piepants (3/3/2019)[/b][hr]Hello, I'm getting the following... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, Yes I used the 4.21 version of the plugin by placing the... By Piepants ( 6 Years Ago )
Forum Post Hi Piepants, We'd like to double check your process. Did you install... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, I cleared out my engine and rebuilt 4.21.2 from scratch,... By Piepants ( 6 Years Ago )
Forum Post Seems like the issue I had yesterday... My mistake was that I dropped... By LiBraga ( 6 Years Ago )
Forum Post Hi Kiwi-Hawk, Thanks for your update. To replace the existing... By Miranda (RL) ( 6 Years Ago )
Forum Post Hey, any new information about when the version 2.0 will be uploaded... By SWGames ( 6 Years Ago )
Forum Post Hi everyone, Thanks for your patience! Plugin Beta 2.0 just released.... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (3/15/2019)[/b][hr]Hi everyone, Thanks for... By rogyru ( 6 Years Ago )
Forum Post Hi Miranda, Works fine but is there a possibility to keep the smooth... By mtakerkart ( 6 Years Ago )
Forum Post Hello! Nah, I know it's not logical, but You have to do it in a... By macsklad ( 6 Years Ago )
Forum Post Thank you Macsklad but I did it before posting but it doesn't works.... By mtakerkart ( 6 Years Ago )
Forum Post Hi Marc, Have you tried Flat Tessellation? By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda , Yes I tried it too. By mtakerkart ( 6 Years Ago )
Forum Post for me tessellation works best when you bake all textures to ONE... By StyleMarshal ( 6 Years Ago )
Forum Post Hi everyone, Some features you requested have been implemented to... By Miranda (RL) ( 6 Years Ago )
Forum Post Hello! Trying out the new 2.0 Unreal and Nice Skin! Wow, very... By TonyDPrime ( 6 Years Ago )
Forum Post [quote][b]TonyDPrime (3/28/2019)[/b][hr]Hello! Trying out the new 2.0... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, thank you so much. Unfortunately I have discovered that... By TonyDPrime ( 6 Years Ago )
Forum Post [quote][b]TonyDPrime (3/31/2019)[/b][hr]Hi Miranda, thank you so much.... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, thank you so much for the suggestion. Kind of funny,... By TonyDPrime ( 6 Years Ago )
Forum Post Hi Tony, This is how you access to the interface for tweaking the... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, thank you for taking the time to show us this. When I do... By TonyDPrime ( 6 Years Ago )
Forum Post [quote][b]TonyDPrime (4/2/2019)[/b][hr]Hi Miranda, thank you for... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi everyone, We are evaluating the Unreal 4.22 now. I will update the... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (4/3/2019)[/b][hr]Hi everyone, We are... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi everyone! Beta 2.1 just updated for adding mask on LW Shader and... By Miranda (RL) ( 6 Years Ago )
Forum Post When imported fbx with Beta2.1, LW/HQ Shader options are grey, I... By astron10 ( 6 Years Ago )
Forum Post Hello astron10, Have you copied the Content folder to the project?... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (4/3/2019)[/b][hr][quote][b]TonyDPrime... By TonyDPrime ( 6 Years Ago )
Forum Post Miranda, I have discovered how this can work. If you add a... By TonyDPrime ( 6 Years Ago )
Forum Post Thanks Tony! I will bring your suggestions to Dev Team for further... By Miranda (RL) ( 6 Years Ago )
Forum Post Guys you need to do another Update to Unreal 4.22 which as Release for... By zeoniknights ( 6 Years Ago )
Forum Post [quote][b]zeoniknights (4/2/2019)[/b][hr]Guys you need to do another... By StyleMarshal ( 6 Years Ago )
Forum Post i hav e a small issue sometimes wehn exporting a character to unreal,... By Ellessarr ( 6 Years Ago )
Forum Post [quote][b]Ellessarr (5/8/2019)[/b][hr]i hav e a small issue sometimes... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (5/8/2019)[/b][hr][quote][b]Ellessarr... By Ellessarr ( 6 Years Ago )
Forum Post Edited: Wrong information was given in this comment. Please find the... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (5/13/2019)[/b][hr][quote][b]Ellessarr... By Ellessarr ( 6 Years Ago )
Forum Post Edited: Wrong information was given in this comment. Please... By Miranda (RL) ( 6 Years Ago )
Forum Post Quick update! Dev Team might revise the code a bit to make it better.... By Miranda (RL) ( 6 Years Ago )
Forum Post another good tip about using "tga(targa format) is which it can be... By Ellessarr ( 6 Years Ago )
Forum Post Thank you Ellessarr. This is what we enhanced in CC 3.04 & Auto-Setup... By Miranda (RL) ( 6 Years Ago )
Forum Post When installing the plugin to my project\plugins folder. 1>... By kmitchell.12catblackstudios ( 6 Years Ago )
Forum Post Hi Kevin, We observed the same issue after upgrading to Unreal 4.21... By Miranda (RL) ( 6 Years Ago )
Forum Post When I moved the one that error-ed out into the engine folder yes the... By kmitchell.12catblackstudios ( 6 Years Ago )
Forum Post Hello! Any idea why does it look like that after CC auto tool imports... By frik.gamedev ( 6 Years Ago )
Forum Post [quote][b]frik.gamedev (8/3/2019)[/b][hr]Hello! Any idea why does it... By Miranda (RL) ( 6 Years Ago )
Forum Post By the way, if i use "Default" import i take much more better result... By frik.gamedev ( 6 Years Ago )
Forum Post Hi! I have a strange problem, I have no buttons to confirm the Auto... By macsklad ( 6 Years Ago )
Forum Post [quote][b]macsklad (9/22/2019)[/b][hr]Hi! I have a strange problem, I... By Am7add9 ( 6 Years Ago )
Forum Post Yes! By macsklad ( 6 Years Ago )
Forum Post [quote][b]aeolian (9/22/2019)[/b][hr][quote][b]macsklad... By macsklad ( 6 Years Ago )
Forum Post Having the same issue but I cant even see the HQ option :(... By davydmayfield ( 6 Years Ago )
Forum Post [quote][b]macsklad (9/22/2019)[/b][hr]Hi! I have a strange problem, I... By Peter (RL) ( 6 Years Ago )
Forum Post Hi, New here, I am just wondering when will the plugin be updated to... By hydra.wang ( 6 Years Ago )
Forum Post [quote][b]hydra.wang (9/26/2019)[/b][hr]Hi, New here, I am just... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (9/30/2019)[/b][hr] Yes, it's planned, and... By codephunk ( 6 Years Ago )
Forum Post Is this update still on track for late October launch? By Power Ten Productions ( 6 Years Ago )
Forum Post [quote][b]richie_994603 (10/22/2019)[/b][hr]Is this update still on... By Miranda (RL) ( 6 Years Ago )
Forum Post Hello everyone! The Auto Setup officially support Unreal Engine 4.23.... By Miranda (RL) ( 6 Years Ago )
Forum Post If you are using a c++ project and need the plugin place the plugin in... By kmitchell.12catblackstudios ( 6 Years Ago )
Forum Post Does the auto import plugin work on source built engines? I cant get... By StudioZ3D ( 6 Years Ago )
Forum Post Hello Miranda there's a problem with eyelashes and hairs when using... By mechatrex69 ( 6 Years Ago )
Forum Post Hello~ I checked with the Dev Team. It's a defect confirmed by... By Miranda (RL) ( 6 Years Ago )
Forum Post hi Miranda thanks for your help 1. PostProcessVolume > Change... By mechatrex69 ( 6 Years Ago )
Forum Post Hi mechatrex69, Click on the material, and you will find the option.... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi all, A friend of mine exported a character from latest CC (3.2). He... By Makumba666 ( 6 Years Ago )
Forum Post [quote][b]Makumba666 (11/23/2019)[/b][hr]Hi all, A friend of mine... By Miranda (RL) ( 6 Years Ago )
Forum Post I think there is a bug with the AutoSetup 1.2 for a character. I have... By ryobg ( 6 Years Ago )
Forum Post Hello, UE 2.24 was released before week. What is your schedule for an... By ryobg ( 6 Years Ago )
Forum Post [quote][b]ryobg (12/15/2019)[/b][hr]Hello, UE 2.24 was released before... By kmitchell.12catblackstudios ( 6 Years Ago )
Forum Post Hi, that's not the point I think? I had to move to 4.24 because of a... By ryobg ( 6 Years Ago )
Forum Post Super cool plugin, I just went through the process of manually setting... By victor.stan ( 6 Years Ago )
Forum Post Thanks Kevin for sharing your experience! @ryobg, victor.stan There... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote]P.S. It's good to know your urgent demand for the updated... By Nekronata ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (12/18/2019)[/b][hr]Thanks Kevin for sharing... By sibi_naayagam ( 6 Years Ago )
Forum Post Thank you all! It's a great encouragement. I will bring your words... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]sibi_naayagam (12/22/2019)[/b][hr][quote][b]Miranda (RL)... By kmitchell.12catblackstudios ( 5 Years Ago )
Forum Post The UE4 Auto Setup Plugin is just awesome and a real time saver! :) By codephunk ( 6 Years Ago )
Forum Post Hi Miranda the new digital human shader CC3.2 seems not working with... By mechatrex69 ( 6 Years Ago )
Forum Post [quote][b]mechatrex69 (12/31/2019)[/b][hr]Hi Miranda the new digital... By Miranda (RL) ( 5 Years Ago )
Forum Post ETA for when Auto Setup will be compatible with Unreal 4.24? By vinny.jordan ( 5 Years Ago )
Forum Post [quote][b]vinny.jordan (1/10/2020)[/b][hr]ETA for when Auto Setup will... By Peter (RL) ( 5 Years Ago )
Forum Post Hello everyone! The UE4.24-compatible Auto Setup plug-in just... By Miranda (RL) ( 5 Years Ago )
Forum Post Hooray! Many gratz to the team! By ryobg ( 5 Years Ago )
Forum Post [quote][b]kmitchell.12catblackstudios... By sibi_naayagam ( 5 Years Ago )
Forum Post Can no longer select any other Shader besides "Standard Shader" on... By umarb8 ( 5 Years Ago )
Forum Post Thank you very much for the Update :), updated my Unreal :) By Nekronata ( 5 Years Ago )
Forum Post Hello i found a strange situation When I use auto setup import... By mechatrex69 ( 5 Years Ago )
Forum Post [quote][b]mechatrex69 (3/3/2020)[/b][hr]Hello i found a strange... By Miranda (RL) ( 5 Years Ago )
Forum Post Hi,Thanks a lot for the plugin, I love it. But When I try to create a... By Onidra ( 5 Years Ago )
Forum Post Hi, When I try to create a package of my game, I can't launch it.... By Onidra ( 5 Years Ago )
Forum Post [quote][b]Onidra (3/10/2020)[/b][hr] When I try to create a package of... By unit23 ( 5 Years Ago )
Forum Post Hi, I'm using UE 4.24.3 And I have the last version of the plugin,... By Onidra ( 5 Years Ago )
Forum Post hi I'm facing some problems when importing character with motion in... By mechatrex69 ( 5 Years Ago )
Forum Post [quote][b]mechatrex69 (3/12/2020)[/b][hr]hi I'm facing some problems... By unit23 ( 5 Years Ago )
Forum Post hey man thanks for your tips after fighting for a day I figure it out... By mechatrex69 ( 5 Years Ago )
Forum Post [quote][b]mechatrex69 (3/12/2020)[/b][hr]hey man thanks for your tips... By unit23 ( 5 Years Ago )
Forum Post I'm having an issue that I can't find any reference to on the boards... By WSAnim ( 5 Years Ago )
Forum Post Try non fixed setting ( IClone and UE4 are not in Sync via... By StyleMarshal ( 5 Years Ago )
Forum Post Thanks, I'll give that a go! By WSAnim ( 5 Years Ago )
Forum Post Yup! Ignore that part on the RL tutorial. Also after the recording per... By kungphu ( 5 Years Ago )
Forum Post Had another issues I had to deal with first, and haven't had a chance... By WSAnim ( 5 Years Ago )
Forum Post Ok, using the Sequence Recorder seems to have worked properly now,... By WSAnim ( 5 Years Ago )
Forum Post Here is the explanation :... By StyleMarshal ( 5 Years Ago )
Forum Post Is there an ETA when the Plugin will get an update for UE 4.25? :)... By codephunk ( 5 Years Ago )
Forum Post [quote][b]codephunk (5/31/2020)[/b][hr]Is there an ETA when the Plugin... By Peter (RL) ( 5 Years Ago )
Forum Post [quote]The update is currently scheduled for the second week of June.... By codephunk ( 5 Years Ago )
Forum Post I am needing the plug-in in 4.25 as well.... this is the last plugin... By bobcober_667673 ( 5 Years Ago )
Forum Post Hi, i am installing Unreal Engine 4.25 for PS4. I need all updates for... By rino.deastis ( 5 Years Ago )
Forum Post Hi everyone, Unreal Auto Setup & Live Link are also updated to be... By Miranda (RL) ( 5 Years Ago )
Forum Post Hi everyone, Really appreciate your feedback on the fix frame... By Eric C (RL) ( 5 Years Ago )
Forum Post Hi. I am trying to download the tool but the download button just... By mybadstudios ( 5 Years Ago )
Forum Post Hi everyone, the reallusion support team redirected me here. Our team... By DonPoko ( 5 Years Ago )
Forum Post [quote][b]fiesta96 (6/16/2020)[/b][hr] Though if I import an older... By unit23 ( 5 Years Ago )
Forum Post Hello~ auto setup import character Will still lose the effect of... By mechatrex69 ( 5 Years Ago )
Forum Post [quote][b]mechatrex69 (6/19/2020)[/b][hr]Hello~ auto setup import... By Miranda (RL) ( 5 Years Ago )
Forum Post Hi everyone, Sorry for the late post! After having spoken... By Eric C (RL) ( 5 Years Ago )
Forum Post Are these issues related to the current use of deprecated functions by... By WSAnim ( 5 Years Ago )
Forum Post Yep, I have the CC_Shader folder fully updated to 4.25 By DonPoko ( 5 Years Ago )
Forum Post [quote][b]fiesta96 (6/29/2020)[/b][hr]Yep, I have the CC_Shader folder... By unit23 ( 5 Years Ago )
Forum Post there's something wrong with hair shader using autosetup Version 1.04... By mechatrex69 ( 5 Years Ago )
Forum Post I only tried this in Unity so not sure if it is the same in Unreal but... By mybadstudios ( 5 Years Ago )
Forum Post Try to deactivate "Cast Ray Traced Shadows" in your Light source. If... By StyleMarshal ( 5 Years Ago )
Forum Post thanks Bassline303 the hair looks the same after I apply the setting... By mechatrex69 ( 5 Years Ago )
Forum Post Speaking of hair... using the classic taper style, on import into UE4... By WSAnim ( 5 Years Ago )
Forum Post Hi, is the source code of the Auto Setup plugin somewhere available?... By andgeno ( 5 Years Ago )
Forum Post Hi, Do you know when the update for Unreal 4.26 would be released?... By sibi_naayagam ( 5 Years Ago )
Forum Post I too would like to know when the plugin will be available for Unreal... By jamesgti14 ( 5 Years Ago )
Forum Post plz update it and add 4.26 support ;-) By Inoland ( 5 Years Ago )
Forum Post Guys it takes like 2-3 weeks till the new engine is supported usually.... By kmitchell.12catblackstudios ( 5 Years Ago )
Forum Post While 4.26 final was "just" released, it has been in beta stage for a... By WSAnim ( 5 Years Ago )
Forum Post [quote][b]WSAnim (12/9/2020)[/b][hr]While 4.26 final was "just"... By kmitchell.12catblackstudios ( 5 Years Ago )
Forum Post Hello everyone! Auto Setup is now compatible with UE4.26. Please... By Miranda (RL) ( 5 Years Ago )
Forum Post Awesome! Thanks a lot, Miranda! By sibi_naayagam ( 5 Years Ago )
Forum Post [quote][b]Miranda (RL) (12/28/2020)[/b][hr]Hello everyone! Auto Setup... By kmitchell.12catblackstudios ( 5 Years Ago )
Forum Post Import a daz genesis 8 character to iclone7 and transfer it to ue4... By xermao ( 4 Years Ago )
Forum Post [quote][b]xermao (1/17/2021)[/b][hr]Import a daz genesis 8 character... By StyleMarshal ( 4 Years Ago )
Forum Post When importing a new fbx into the editor as an asset, the editor will... By realtrainingsystems ( 4 Years Ago )
Forum Post Use HQ or LW (standard has this issue) By lianchiu ( 4 Years Ago )
Forum Post Is it possible to bug in iClone Live Link !!! Is there a solution!... By nikofilm ( 4 Years Ago )
Forum Post Try this By lianchiu ( 4 Years Ago )
Forum Post Dear Colleagues, We faced with issue during working of AutoSetup... By character-creator ( 4 Years Ago )
Forum Post try to delete the content > CC_Shader and Plugins > AutoSetup in... By lianchiu ( 4 Years Ago )
Forum Post Can this be modified with our own Custom Shader Links? I've made... By kmitchell.12catblackstudios ( 4 Years Ago )
Forum Post the download for the latest auto-setup plugin is somehow the previous... By BloodPawWerewolf ( 4 Years Ago )
Forum Post [quote][b]BloodPawWerewolf (3/24/2021)[/b][hr]the download for the... By lianchiu ( 4 Years Ago )
Forum Post Hi everyone! Auto Setup is updated to be compatible with UE4.27.... By Miranda (RL) ( 4 Years Ago )
Forum Post [quote][b]Miranda (RL) (8/31/2021)[/b][hr]Hi everyone! Auto Setup is... By Jeasy ( 4 Years Ago )
Forum Post [quote][b]Miranda (RL) (8/31/2021)[/b] Auto Setup is updated to be... By davood.kharmanzar ( 3 Years Ago )
Forum Post Same here, very intersted by a pre-release UE 5.0 plugin for test By Patrick_AIV ( 3 Years Ago )
Forum Post I came across the an issue and I am sure this has been answered, so my... By cstrauss42a ( 3 Years Ago )
Forum Post Even the hair in the Reallusion store is transferred quite... By yepkoo ( 3 Years Ago )
Forum Post Well that is some what good to know, that I did not necessarily... By cstrauss42a ( 3 Years Ago )
Forum Post Could you please tell us any plans for UE5 ? By HenrySuen ( 3 Years Ago )
Forum Post UE5.0 is out. Any updates? By HenrySuen ( 3 Years Ago )
