Issue 3: How to animate using bone
Posted By hi_022884 8 Years Ago
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
hi_022884 (1/4/2019)
One more thing... I am not able to change poses of G2 character in the composer. Each time I try to rotate, it comes back to original position. Why?
Composer Mode is only for creating/changing/modifying a characters base body parts. It has NOTHING to do with Stage Mode or the position/transformation/animation of the character on the stage.
Consider Composer Mode as a separate program that you send your character to for editing of the body parts, There is No Animation in Composer Mode.
When exiting Composer Mode your character is sent back to Stage Mode where you would animate it.
ALL animation/posing/rotation/transformation/etc. is done in Stage Mode.
Jeff
vidi
vidi
Posts: 10.8K, Visits: 40.2K
My suggestion rereading the tread, because this is a spinning in a circle . you ask always the same question and get the same answers.
liebe Grüße vidi
Posts: 23.1K, Visits: 36.6K
https://www.dropbox.com/s/c5gh9k4yeyap4s8/Issue%203.1.mp4?dl=0
Composer Mode is for the creation and setting up of your characters. It's not for posing or animating them. You should do the posing and animating in Stage mode. Just select your G2 character in Stage mode and click the 3D Motion Key Editor (M) from the left side toolbar. Then you can pose your character and rotate as you wish.
hi_022884
hi_022884
Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)
Last Active: 7 Years Ago
Posts: 20, Visits: 36
hi_022884
hi_022884
Thanks I'll check it out
vidi
vidi
Seems  you  need still  some basic programm  infos .
liebe Grüße vidi
hi_022884
hi_022884
Otherwise? If it is G1, G2+ or G3 then?
vidi
vidi
if it is a G2 Character use the 3D Motion key editer
liebe Grüße vidi
hi_022884
hi_022884
Then if I want to make animation using the side pose of the same character then what should I do?
vidi
vidi
For this we need to switch composer mode right?
No,  the composer mode is only for creating and adjust your Character and Sprites  and these direction thing is for checking your Character.setup .
liebe Grüße vidi
