How to tweak PopcornFX library 40 with the plugin
Posted By zvonimir.tusek 6 Years Ago
zvonimir.tusek
zvonimir.tusek
Veteran Member (852 reputation)Veteran Member (852 reputation)Veteran Member (852 reputation)Veteran Member (852 reputation)Veteran Member (852 reputation)Veteran Member (852 reputation)Veteran Member (852 reputation)Veteran Member (852 reputation)Veteran Member (852 reputation)
Posts: 20, Visits: 121
Hi, I want to tweak PopcornFX library 40 presets with plugin, for example, I want to make fur particle strands less "movable"... I must import pkfx format, but the presets in library are in iPkfx format.
BR.
Zvonimir
Posts: 5.7K, Visits: 26.4K
The Reallusion iPkfx files can not be edited with the PopcornFX software.
zvonimir.tusek
zvonimir.tusek
On Library page
https://www.reallusion.com/ContentStore/iClone/pack/Particle_Effects-popcornFX_Library40/
is a paragraph:
If you want to tweak existing particle behaviors, import images, sprite textures, 3D meshes and sounds you can sample a static, skinned, or blendshaped mesh for the emitter shape, please acquire the PopcornFX Plug-in for iClone.
The PopcornFX plugin allows you to make changes to a particle inside iClone, this is not the same as the PopcornFX software. To make changes to a .pkfx file simply Drag and Drop the file in to iClone and you can make changes there using the Modify Panel - this requires that the Reallusion PopcornFX plugin is installed on your system. After making changes you can save the effect as a custom .iPkfx file.
The amount of parameters that you can adjust is restricted to the number and type present in the imported .pkfx file.
6 Years Ago by wires
zvonimir.tusek
zvonimir.tusek
So without the plugin there is no modify panel... Tnx.
