fine tuning motion puppet with edit motion layer?
Posted By johnwarndt52 2 Years Ago
johnwarndt52
johnwarndt52
Veteran Member (908 reputation)Veteran Member (908 reputation)Veteran Member (908 reputation)Veteran Member (908 reputation)Veteran Member (908 reputation)Veteran Member (908 reputation)Veteran Member (908 reputation)Veteran Member (908 reputation)Veteran Member (908 reputation)
Posts: 111, Visits: 229
I'm having tremendous trouble using motion puppet, although I see its potential. I'd like to use the Edit Motion Layer feature to make small changes on the timeline to movements that I've already added using Motion Puppet, as that gives you SO much more control of the avatar's limbs, but once I make a change, it will immediately snap back in the very next frame to the trajectory that Motion Puppet has given it, even if I keep making small changes along the timeline. Is there any to plug in a command that changes that trajectory smootlhly without using Motion Puppet again? I hope that makes sense. I'm a noobie.
