sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
I get the following message in BOTH iClone 7.2 and 7.3 Any ideas? (thanking anyone who can solve this mystery).
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Question: Did you download and install this package from your user account?
I can be wrong, but I think then the moves should be backIt is worth a try
Greets from Germany Postfrosch
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Thanks - I'll give that a try (I thought I had everything loaded - but maybe not - I'll check) (btw I had re-installed v7.2 yesterday, but even so, was having this issue earlier - when 7.3 was installed) Anyway, the 'Bonus Pack' that's currently installed is: 7.2.1220.1 So do I need to install any other Bonus pack or files as well?
6 Years Ago by
sonic7
Last Active: 6 minutes ago
Posts: 5.7K,
Visits: 26.4K
Make sure that you also have the following Sub-Folders in your MographMotion Root
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
This is what's there Gerry ......
Posts: 5.7K,
Visits: 26.4K
If all of those files are in place then everything should work OK. The Bonus Pack that you mentioned is the only one available and is for any iClone 7 version, while the Resource Pack on the download page will only work with 7.3.
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
The 'message' calls for a Folder named 01_G5 Motion_Chuck - correct? - which has not been installed to the 'Motion' folder ... correct? So, why wouldn't that Folder be there? I installed 7.2 with the following order: 1. IC7_Enu 2. IC7_Enu_Resource_Pack 3. iC721_Multi_Full_Patch 4. IC7_Enu_Bonus_PackJust now I tried 're-loading' in the Bonus Pack - but it's still the same result .... So what software is responsible for installing this Folder?
6 Years Ago by
sonic7
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
You have to (probably) reinstall the resource pack for 7.2. These packs must (should) be reinstalled each time the version is changed
Greets Postfrosch
So what software is responsible for installing this Folder? Should be a * .exe file or it will be installed automatically via rdl
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Thanx Postfrosch - I'll give that a go ......
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Nope .... same result. Both Chuck and Gwynn display the same message when right clicking 'Move' > 'Walk Forward' .... even for a 'straight' walk (without a path).
The 'Nude Characters' work fine. The G6 Characters work fine. The Clone Bone Characters work fine.
The G3 Character 'Benny' displays a different error message .... "Error Adding Move Command" Kane, Trey, Trinity and Violet - also display ... "Error Adding Move Command" The G5 'Outfit Collection' all fail and show the same 'original' error message.
The G6 'Outfit Collection' all work fine. The 'Non-Standard Humans 'Dummy' and 'Sack' work fine. The 'Lamp' works fine.
The CC Characters don't have the 'move' feature - so can't test that.
