Dragonskunk
Dragonskunk
Visits: 1.4K
animagic (10/15/2018)
Dragonskunk (10/15/2018) Here's a doozy of a bug for v7.3.2205.1 Only on my desktop W10 64b v1607
I've found the newer required NVDIA drivers don't work (or don't even install) unless you have at least Windows 10 v1803. So that's not surprising. As long as the Nvidia version is the one iClone requires you to have for it to work installs, and it does, I'm good. Just needs a bit of putting it R and D a few times for it to work.
swordflasher
swordflasher
Visits: 287
my content files will no longer open with a double click my iClone 7 content files will no longer open with a double click. If I go to template or custom projects, actors, motions or props, I have all the headings of my content listed under both template and custom, but when I double click a heading to see the sub-folder thumbnails of my content to open them then nothing happens - the thumbnails do not appear. The files are there, because if I right click I can then find the file and drop it into the scene to open. This started yesterday, had no problems before then. Can you please advise? Thank you.
Posts: 23.1K,
Visits: 36.6K
danmiller (10/9/2018)
I was hoping my issue would be fixed.  Dan... you are going to need to explain more about what you did leading up to that issue occurring. A screenshot with no further details doesn't really help. Note: If you reported it previously, please post a link back to your original report. Thanks.
Posts: 23.1K,
Visits: 36.6K
hj (10/9/2018) Hi Peter
only in "Avatar Custom" and in "Animation Customs" i can not save any thing. I can save Props Creating "New Folders" works only for Projects
my Reallusion "Template" and "Customs" Drive is E: not C:
With CC 3.0 and 3dXchange no Problems. Also with iClone 7.23 no Problems The Problem started wit 7.3
best Hans Jörgen
Hi HJ If you are still having this issue, please do report it to Technical Support so the issue can be logged and investigated further. Thanks. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
Posts: 15.8K,
Visits: 31.4K
Dragonskunk
Dragonskunk
Visits: 1.4K
I rolled back then I rolled forwards now it works I'll see if I restart or load projects and see if it vanishes again.
Dragonskunk
Dragonskunk
Visits: 1.4K
Here's a doozy of a bug for v7.3.2205.1 Only on my desktop W10 64b v1607 not my laptop W10 64b v1803 iClone will not show my timelineMANUAL SAYS: You can open the Timeline panel in any of the following ways: - Access the Window >> Timeline command from the main menu bar.
- Use the hotkey F3.
- Click the Timeline button on the play bar.
All 3, it's NOPE, NOPE, and NOPE. Existing projects or a new project. Any workspace. I'm gonna have to roll back.
bexley
bexley
Visits: 374
Thanks for the tip -- I didn't realise there WAS a feedback tracker! <D'oh!>
--Bex.
@Bexley - Please enter it into Feedback Tracker (complete with your great pictures that demonstrate the problem). That way the issue doesn't get lost in the forum fog and clutter. I hope they fix it.
bexley
bexley
Visits: 374
The TOON Shader has become unusable -- I posed a rant in the Technical issues forum (sorry) but the problem is that outlines are too thick and the NormalThreshold (probably due to the line width) causes spots to appear where they shouldn't (the tip of her nose, for example). Below is a comparison between 7.3 and 6.5 toon renders -- both made at exactly the same res. as close to the same circumstances as possible:  As you can see, the results are significantly different, and the one on the left (7.3) is garbage. Please tell me this will be fixed. --Bex.
