georgeparker789
georgeparker789
Last Active: 8 Years Ago
Visits: 2
This is cool, and I am looking for the same in my favorite game.
Posts: 5.3K,
Visits: 16.8K
Thank you guys! There was indeed a major path enhancement which I do appreciate.
However, I am going back to my FT Issue 3710 (which has Released in IC7.3 status).
I stated 2 problems back then:
1. Follow path. It seems to be partially fixed. The object does not sync into the underling surface anymore. Big +. But it still tilts by the wrong axis as before, when it hits the curve. 2. Follow terrain. This one is not fixed at all. The problem persists.
Please see freshly made video in IC 7.3, where both problems are clearly displayed:
Excellent post, Tony(RL). Very clear and informative.
These are awesome "Path" enhancements. Well done, Reallusion.
Tony (RL)
Tony (RL)
Last Active: 6 Years Ago
Visits: 1.7K
iClone Path Tutorial Videos
1. Getting Started with Motion Paths
- Path Creation & Editing
- Moving a Prop Along a Path
- Bezier Curve Editing
- Transform Editing in the Timeline
2. Applying Objects to a Path
- Attaching Cameras to a Path
- Having a Character Run Along a Path
- Attaching Particle Effects to a Path
- Attaching Lights to a Path
3. Bezier Curve Editing for Paths
- Creating & Editing Multiple Paths
- Path Curve Options
- Animate & Refine Path Movement
Tony (RL)
Tony (RL)
Visits: 1.7K
Path Offset
Path Offsets supports translation, rotation and scale. However only rotation and scale can be keyframed.
Move (Translation)
Rotate
Scale
Tony (RL)
Tony (RL)
Visits: 1.7K
Path Position
Path Position can be tweaked to adjust how positioning and timing relate for the path constraint.
Dots will begin to appear as the object advances down the path according to the Path Position keys. Besides being able to observe the positioning of the object, one can also get a sense of speed at which it travels down the path. Since every dot represents a single frame; one can surmise that densely packed dots equate to slower speeds while distant dots represent faster speeds. See the examples below:
1. Uniform velocity:
2. From low to high velocity:
3. From high to low velocity:
Tony (RL)
Tony (RL)
Visits: 1.7K
Path Position & Offset Editing - UI Overview
For objects following a path, the Position and Offset parameter can be adjusted to deviate from the curve's trajectory.
1. Path Position 2. Path Offset
For the tutorial video, go here.
Tony (RL)
Tony (RL)
Visits: 1.7K
Show & Hide Bezier Handles
Show and Hide Bezier Handles are now available in the right-click context menu for the path in Edit Point mode.
Tony (RL)
Tony (RL)
Visits: 1.7K
Unify & Break Tangents
Unify and Break Tangents are now available in the right-click context menu for the path in Edit Point mode.
Tony (RL)
Tony (RL)
Visits: 1.7K
Change Path Type
By right-clicking on the path curve under Edit Point mode, one can change the path type to Bezier, Linear, or Smooth. This function works on the selected control points as well as the entire path.
Bezier
 Linear
Smooth
