Mystery (to me) involuntary stroke on prop when rendered on transparent background
Posted By peterg 8 Years Ago
Mystery (to me) involuntary stroke on prop when rendered on...
peterg
peterg
Posts: 48, Visits: 375
I have gone through basically all settings but cannot figure this one out. A complete mystery, hoping for an iclone magician out there ;-)  On latest Iclone version.
I am trying to render a scene with a transparent background, but one of the props in the scene is creating a stroke and shadow effect when it is on a transparent background. See example image. I have placed a floor and a sphere to demonstrate that as soon as there is a background, the stroke is removed. The tractor was an OBJ that was imported through 3DXchange.
https://forum.reallusion.com/uploads/images/94462cf3-4c27-4d9a-b876-c4e6.png
On the image you can cleary see the stroke starting as soon as it's on transparent. If I set a white background all of the stroke is removed, and it only affects the tractor prop, not the avatar or the sphere prop in the example. I have also included the material settings, but I have gone through and tested all I can think of there as well.
Thanks for reading this post :)
https://forum.reallusion.com/uploads/images/61ed4717-075c-4e20-916d-93a3.jpg
Posts: 5.3K, Visits: 16.8K
A glow map on a tractor is causing a "shadow like" stroke.
peterg
peterg
Yes, you are correct, thank you 4uges! I could swear I tested with and without, but I did like 50 modifications to test what caused it.
peterg
peterg
Small side note, even with the strength of the glow layer set to zero, it still causes the stroke/shadow. I had to delete it to remove it.
peterg (8/19/2018)
Yes, unfortunately it wont go away even if you set control to 0. It actually should be considerate as a bug reported to Feedback Tracker https://www.reallusion.com/feedbacktracker/
