Kinect v2 doesn't work...
Posted By evacrystal 6 Years Ago
evacrystal
evacrystal
Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)
Posts: 3, Visits: 41
Hi!
I bought the Kinect Mocap Plugin Windows 1.2 and unfortunately it doesn't wok. I attached 2 images:
https://forum.reallusion.com/uploads/images/655305cd-1a83-4847-aa61-1c3d.png
https://forum.reallusion.com/uploads/images/e044ce97-825b-484a-be78-9929.png
So how do I use iClone plugin???
Thanks!
Last Active: 10 hours ago
Posts: 22.7K, Visits: 35.7K
There are three versions of the Kinect plug-in available depending on the model of Kinect you have. It is very important you only install  the correct plug-in for your device.
So if you are using a "Kinect For Xbox One" then you need version of plug-in called "Mocap Device Plug-in (Kinect for Xbox One)".  You should not install any other version of the plug-in.
You also must have a fully compatible USB 3.0 port that is not being used by any other device (don't use a hub).
If you still have problems after checking the above, please tell us which Kinect you are using, if it is the trial or full version, and also supply your computer specs and operating system. Thanks.
evacrystal
evacrystal
Thank you! It solved.
