LIpstick Creation Prop Modification
Posted By mayaenvogue2016 7 Years Ago
mayaenvogue2016
mayaenvogue2016
Posts: 51, Visits: 216
Hi,
can anybody explain how can I change a prop mesh so that my lipstick applicator looks authentic? Below there are 2 pics for comparison: the real lipstick applicator has a special top with a "cut-off" look, which is designed to make it easy to apply the lipstick and it is the important feature of  it.  The one I have created - on the other pic-does not. I have tried to combine two props to create a  somehow realistic-looking top, but it is not satisfactory. Maybe anybody can help with a good idea how I can edit mesh, or, even better: Does Reallusion have any specialized prop-creating software? I do not want to use any external prop creating software (like Blender etc) on this stage. Many thanks in advance for your suggestions.
https://forum.reallusion.com/uploads/images/37b7b5b6-03ee-4fac-acaa-6914.jpg
https://forum.reallusion.com/uploads/images/b6fa267f-c479-4c72-9532-7ab2.jpg
Last Active: 4 Months Ago
Posts: 5.7K, Visits: 26.5K
There is perhaps a way to what you want using just iClone and Character Creator, but I don't know if the result would be 100% perfect for your needs.
In iClone select one of the default CC characters and then attach a Cylinder from the 3D Block Props folder to it - Cylinder_004 may be the best choice. I wouldn't worry too much about the size of the cylinder at the moment. Select the Character and then select "Edit in Character Creator" in the Modify Tab. In CC select the Cylinder and then "Edit Mesh". It "should" be possible to make adjustments to make it look like a Lipstick.
If, and when, you get the result that you want send the Character, with attached Cylinder, back to iClone. In iClone detach the cylinder from the Character and save it as a Prop that you can use to build your own Lipstick after scaling.
mark
mark
Posts: 4.9K, Visits: 16.7K
Brilliant thought Gerry! Never would have thought of that. And while I might have been able to achieve it a little faster in Lightwave or Blender it worked pretty good! Bravo! :D
PROMO-BACK2
4413Media
4413Media
Last Active: 8 Months Ago
Posts: 394, Visits: 7.4K
There is a way, it is sadly in Blender, but it is incredibly simple and it takes less than a minute to do. It involves a Boolean modifer. When I have the time tonight, I can provide a very quick tutorial covering this or if you are able to, I can easily modify the mesh.
iClone Certified Director and makes miserable Westerns.
Tho OP clearly asked for a solution without using 3rd party SW.
4413Media
4413Media
I am aware of that, but editing the mesh in the software would not achieve the best results in that image above. A Boolean cut with a slight bevel is the easiest and quickest option, plus it will be the best look by producing that sharp cut as seen with the image. Limited options though, it's why I jumped to the Boolean solution. It's a lot easier to have a mesh cut through another with a click of a button than mess with vertices :)
JimmyB7
JimmyB7
Posts: 198, Visits: 3.2K
wires (7/24/2018)
I tried this just for fun and it works amazingly.  I used the "Smooth" function to shape the cylinder.  I have no final product to show as it would take some effort to get it perfect.  I just wanted to verify it is doable.:D
CyberpowerPC, 64 GB Ram, 64bit Windows 10 Pro, Intel Core i9-10980XE 18 Core CPU,  ASUS TUF X299 Mark 1 Motherboard, ROG-STRIX-RTX2080TI-O11G-GAMING graphics card, Toshiba 3TB hard drive, 3 x Seagate 3TB hard drives, RAGNAROK 801 Full Tower, LEPA G1600 1600W power supply, Killer WI-FI 6,  ASUS PA329Q 32" 4K/UHD IPS Monitor.
JimmyB7
JimmyB7
About 2 minutes in Character Creator
https://forum.reallusion.com/uploads/images/6b224516-808a-4746-aace-a156.png
Delerna
Delerna
Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)
Posts: 1.5K, Visits: 14.8K
I have seen some comments in the past relating to linking props to characters and working with them in CC but been too busy with other things to look into its possibilities. One thing I do wish is that iClone had a similar ability to adjust objects meshes like CC can with clothes and characters. Now I finally see its possible to send props to CC and edit their meshes there. Thank you for pointing this out wires. Much appreciated and I will definitely be looking into discovering the possibilities of this now.
I still wish we could do it to props in iClone too but it is what it is and I just use whatever I know is available to do what I need.
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
Delerna
Delerna
Oh, and I meant to thank you too JimmyB7 for showing what you did. Helped me to see CC's abilities on this topic for my needs better.
