kwhitaker333
kwhitaker333
Posted Last Year
Last Active: 11 Months Ago
Visits: 23
I have animated the face and background successfully. My question is: is there a way to replace the face with a re-rendered face and not have to go back in all over again to reapply everything (anchors, eyes, mouth, ...?
Posted Last Year
Last Active: 32 minutes ago
Posts: 16.7K,
Visits: 25.3K
For both a 2D actor and 3D actor you will need to set the fitting points again if you wish to load a new source image. However for 3D actors you can tweak the head texture to add changes such as scars or makeup without needing to go through the setup process again. You can do this from Create > Texture Settings on the Menu Bar.
