Replace face?
Posted By kwhitaker333 6 Years Ago
kwhitaker333
kwhitaker333
Veteran Member (757 reputation)Veteran Member (757 reputation)Veteran Member (757 reputation)Veteran Member (757 reputation)Veteran Member (757 reputation)Veteran Member (757 reputation)Veteran Member (757 reputation)Veteran Member (757 reputation)Veteran Member (757 reputation)
Posts: 12, Visits: 24
I have animated the face and background successfully. My question is: is there a way to replace the face with a re-rendered face and not have to go back in all over again to reapply everything (anchors, eyes, mouth, ...?
Posts: 22.7K, Visits: 35.7K
For both a 2D actor and 3D actor you will need to set the fitting points again if you wish to load a new source image.
However for 3D actors you can tweak the head texture to add changes such as scars or makeup without needing to go through the setup process again. You can do this from Create > Texture Settings on the Menu Bar.
