Famekrafts
Famekrafts
Visits: 2.0K
Kind of what you see in scooby doo cartoons, a green wavy smoke keeps spreading around the area. What kind of particle emitter should I use for these?
CTA5, Iclone 7, 3D Exchange Pro, Character Creator 3, Popcornfx plugin, Zbrush, Blender, Vue 2014, Adobe cc suite, Spriter Homebuild Workstation (Pretty old now but still working great) Win 10, Intel i7 950, 24 GB RAM DDR3, Gigabyte x58a-ud7 motherboard, AMD R9 390 sapphire 8GB VRAM. Official Website Reallusion Store
Last Active: 20 minutes ago
You should be able to achieve what you want to do with the Smoke particle from the PopcornFX Library 40 pack (Weapons and Explosives). The color of the smoke can be changed to green and you can key wind direction changes to make the smoke swirl about.
Famekrafts
Famekrafts
Visits: 2.0K
Well with smoke particle I manag ed to get the dust smoke done, but not what I need.
I need kind of this effect check at duration 1.24 the green wave spreading across and not smoke moving in any direction.
Famekrafts
Famekrafts
Visits: 2.0K
Bump Guys no help here? Should I try using ribbon particles?
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
It certainly seems to be that sort of look A l-o-n-g 'ribbon' type that 'follows a path' Seems to be a 'blend' of 2 or more irregular 'whisps' or 'strands' Semi opaque, soft edged, narrow pathed. Boy you must have fun playing with this stuff !!!
6 Years Ago by
sonic7
Posts: 5.7K,
Visits: 26.4K
If you have the Learning Samples pack there is one Ribbon effect in the Applications folder named Ghost. By adjusting the Diffuse colour and the emitter speeds you may be able to get what you are looking for. There's quite a few control sliders, so it may take a while to get it right.
Famekrafts
Famekrafts
Visits: 2.0K
Thanks man I will give it a try.
Famekrafts
Famekrafts
Visits: 2.0K
After playing with it for a few minutes I have got the effect I need kind of vapor emitting and then vanishing into the air. Now I do not require it to appear randomly which it does right now. Should I export it as with alpha so I can superimpose the part I need in editing software or is there a way to turn particles into a movie clip which I can break and use a particular part of the effect I need?
Famekrafts
Famekrafts
Visits: 2.0K
Guys any help with the process? Should I export with alpha and use it overlay on the main footage?
Am7add9
Am7add9
Visits: 9.3K
it can be done with a combo of "fog" in the visual tab (tweak distance and color) and using a legacy particle "fog" (tweak texture, color,particle force and size) also the fog particle has a illumination setting if global illumination is turned on
not everything needs to be done with popcorn
