sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Hi ..... regarding Sketchup models >> imported >> into iClone: 'Materials', 'textures', 'base color' etc are all new to me, so for ease, I'm simply adding my 'materials' inside of sketchup. (there's probably better ways). But .... no matter how I try to 're-name' the materials (in SU), the 'material list' that arrives in iClone still has, I'm guessing - all the 'original' names for those materials. Eg: I name a material: "Light Reflector Rear" (in SU) .... and in IC it shows as "Metal_Aluminium_Anodized.jpg" Or I label a material: "King Pole Timber grain" (SU) ..... and in IC it shows as "Chateignier_tangentiel.jpg" I realize this probably isn't iClone's fault - but does anyone happen to know a trick to doing this? ...... thnx Steve.
6 Years Ago by
sonic7
ckalan1
ckalan1
Last Active: 12 hours ago
Visits: 10.5K
I am not sure why you want to change the name but it can be done. There are a few steps that you have to do in Sketchup. In order to change the name, you will need to Select the Texture for your object surface with the default texture of your choice. (The default tray is open to Materials. Have the Materials dropdown open) Click the little cube with the plus sign. This makes the Create Material window popup (It can be found on the right side of the top panel of the Materials dropdown) Give the material a name. Then click OK Now paint the surface of your object Right click on the surface that you just painted and click on Make Unique Texture Now you can save the object as a Sketchup 2015 file and open it in 3dxchange. It should transfer your new texture names.
I am not sure this is what you are trying to do. There is probably a plugin that can do this. If I find one I will pass it along. Craig
ckalan1 (4/26/2018) I am not sure why you want to change the name but it can be done.If you're going to work with the model more than once, it is nice to have meaninful names.
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
