tvwk2013
tvwk2013
Visits: 139
tvwk2013
tvwk2013
Visits: 139
I was trying to do it, but it didn't helped ( the size of this small window is not changing (
Last Active: 7 days ago
Posts: 5.7K,
You appear to be using an unusual screen resolution and that may be causing the sizing problem. Have you tried clicking the "Restore Down" icon and then adjusting the size by dragging the outer window edges to increase the size?
tvwk2013
tvwk2013
Visits: 139
I have an issue with targeting the bones for the Non Standard character in 3DEchange, the window is hiding the part of the left hand and I am not able to move it or resize the screen, may be somebody can help
vidi
Posts: 10.8K,
Visits: 40.2K
Have you interested in an analysis? If not why ?
vidi
Posts: 10.8K,
Visits: 40.2K
As you can see in the videos, the content does have correctly set UVs For that I need to see the UV maps. General, Only properly created UV maps are without trouble if you want share Objects The most sketchup models are troublemaker, because only Material IDs with assign Texture but not right UV mapped Maybe you can upload your file for analyzed ?
Lord Ashes
Lord Ashes
Last Active: 7 Months Ago
Posts: 1.3K,
Visits: 1.6K
vidi (2/2/2021) Looks like the OBJ. have not properly UV maps As you can see in the videos, the content does have correctly set UVs because the material/texture is correct when the content is pushed to 3DXChange from iClone which is what can be seen at the beginning of the video. However, as you indicated, when the content is exported then it looks like it is mixing up the material and/or UVs (Video #2) as well as sometimes dropping parts of the mesh itself (Video #1 but also seen a bit in Video #2).
vidi
Posts: 10.8K,
Visits: 40.2K
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
There seem to be problems using the EXPORT TO OBJ function with a lot of content. So far I have noticed three kinds of issues which affect a large portion of content (at least from the spot check of content that I tried to export): 1. Parts of the exported content has missing meshes 2. The exported textures/materials are wrong 3. The exported files is a corrupt file https://youtu.be/QmcErogPIJ8The original thread in which I noted this can be found at: https://forum.reallusion.com/471414/Major-Issues-With-Export-OBJ-Function
Posts: 5.7K,
I can't help feeling that DAZ are trying to make importing their characters in to RL products as difficult, if not impossible, as they can. :ermm::Whistling:
