iClone 7.x - Morph Creator - Offset & Distortion Issue
Posted By Lord Ashes 8 Years Ago
Lord Ashes
Lord Ashes
Last Active: 8 Months Ago
Posts: 1.3K, Visits: 1.6K
I created a pair of pants which I imported through CC2.3 and then brought into iClone7.3 on a CC2 character.
I then opened Morph Creator to try and add a morph to the pair of pants. I was able to add a clothing morph to a mini skirt so there does not seem to be an issue with adding morphs to clothing.
Initially I had some issues with my morph (not matching the number of vertices), so I got the idea of exporting my mesh from Morph Creator to ensure that I am applying the morph to the correct mesh.
First surprise was that when I exported the mesh from Morph Creator it seemed to have an offset as compared to original. After some though, I concluded that this could be correct because when I was rigging the pair of pants, I did move it. However the second surprise was that the morph failed spectacularly. It did load but when applied it did not look at all like it was supposed to. The other interesting observation was that when I use the morph that was based on the original mesh, the application of the morph in Morph Creator did not produce an offset. Assuming the assumption about why there was a Y offset between my original base mesh and the one exported from Morph Creator was true then I would have expected that when the morph based on the exported mesh is used then it would not have an offset but the opposite seems true.
In any case both morphs failed spectacularly and morph based on the Morph Creator export causes an additional Y offset. As can be seen in the video, the meshes when viewed in a software editing program show perfectly fine (I did not spin them around in the video but I did check that they are fine). I am sure that I will get a few laughs when people notice the software that I am using but when the meshes are loaded into Blender they also appear fine.
Does anyone have any idea what could be causing this?
BTW: I am not sure if it is related but I sometimes saw a similar y-offset introduced when I was working with using character expressions to make morph props (prior to iClone7). However, in these cases applying an offset to compensate usually resolved the problem. In this case the problem is not only the offset.
Threaded View
Threaded View
Forum Post iClone 7.x - Morph Creator - Offset & Distortion Issue By Lord Ashes ( 8 Years Ago )
Forum Post I am not sure if that is your case (I never morphed a cloth), but as a... By 4u2ges ( 8 Years Ago )
Forum Post Thanks. I will give that a try. I have a feeling that may help with... By Lord Ashes ( 8 Years Ago )
Forum Post I managed to get the issue resolved. I rigged the clothing in Blender... By Lord Ashes ( 8 Years Ago )
Forum Post Don't forget you can set the scale in the Blender export panels for... By Rampa ( 8 Years Ago )
Forum Post [quote][b]Rampa (4/2/2018)[/b][hr]Don't forget you can set the scale... By Lord Ashes ( 8 Years Ago )
Forum Post I noticed that the morphs still have distortion after all...it is just... By Lord Ashes ( 8 Years Ago )
Forum Post What is your workflow on this (through Blender I assume). I'd like to... By 4u2ges ( 8 Years Ago )
Forum Post I found one immediate issue which is adding to the frustration of... By Lord Ashes ( 8 Years Ago )
Forum Post Just to add... To compensate for the scale difference between the OBJ... By Lord Ashes ( 8 Years Ago )
Forum Post I think you should skip all the exporting and re-importing steps. If... By Rampa ( 8 Years Ago )
Forum Post [quote][b]Rampa (4/5/2018)[/b][hr]I think you should skip all the... By Lord Ashes ( 8 Years Ago )
Forum Post Thank you Lord for the effort. I am yet to try it. Simple is that.... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (4/5/2018)[/b][hr]It might work for a simple... By Lord Ashes ( 8 Years Ago )
Forum Post Finally managed to get a working morph without distortion... 1. I... By Lord Ashes ( 8 Years Ago )
Forum Post Well that is good news! Glad you got that working. By Rampa ( 8 Years Ago )
Forum Post That's great! Still did not have a change to try. But now I am... By 4u2ges ( 8 Years Ago )
Forum Post I have not yet tried to do hair...I watched a tutorial once but it... By Lord Ashes ( 8 Years Ago )
Forum Post There is a thread started by AncientWire about transforming a skirt so... By 4u2ges ( 8 Years Ago )
Forum Post No real secret...use the work flow as detailed earlier. 1. Created CC... By Lord Ashes ( 8 Years Ago )
Forum Post Boom!! Got it working! I guess I was tired last night and neglected to... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (4/7/2018)[/b][hr]Boom!! Got it working! I guess I... By Lord Ashes ( 8 Years Ago )
Forum Post Thanks, but not really any competition...:) (If I only had time for... By 4u2ges ( 8 Years Ago )
