bela_sieck
bela_sieck
Last Active: 6 Years Ago
Visits: 66
Hello everyone, I don't have much experience with 3D and I currently have only CCLite. I exported an CC character as obj., painted on it in 3d-coat to make it look like porcelain and now want to import the texture back into CC. I can import the diffuse maps, but don't know how to import the reflection, the porcelain-like effect. Is there a way to import the textures as a whole in one step? So that I would just select the exported and painted obj. file and it applies it's textures to the cc character? Thanks :)
Posts: 5.7K,
If you exported all of the Texture/Material images from 3DCoat then you can use these in iClone/CC. You just need to place the correct image in the required Map in the Materials Modify panel. If using PBR then add the Reflection Map to the Roughness slot. 75% of original size (was 670x19) - Click to enlargeIf using the Traditional Materials settings then just add it to the Reflection slot. 75% of original size (was 670x19) - Click to enlarge
gcshep
gcshep
Last Active: 7 Years Ago
Visits: 3.0K
You might find this of help.
Best Regards George
bela_sieck
bela_sieck
Visits: 66
Thanks :). Somehow exporting the specularity from 3dCoat doesn't work. It exports files called ..._specular.psd, but those don't contain any color, they're just transparent. Using them (exported as .png) doesn't have any effect. It does work when I use simple white png.files for specularity.
Is there any method with which I could apply all textures in one step, without applying them one by one?
If I would have 3dxchange pro (not the Pipeline version): Could I export the character from CC as .obj, import it into 3dCoat, change the texture, than export it as .obj and just reimport it into CC, with automatically reintroducing the bones and morps so that I could still pose it in Iclone?
Also: Can I somehow use .psd files in CC or do I have to export them all as .png?
bela_sieck
bela_sieck
Visits: 66
Thanks :) I don't know which of the exported textures I'm supposed to use. If I export the specularity, ist just an empty psd. file, it has no effect when I export as png. and use it for the specularity. I can just create a white png. and use it for specularity.But it's not exactly the same degree of reflection/metalness I created in coat3d.
I need to learn more about 3dcoat... My model in 3dcoat has only layers named ..._roughness or ..._metalness, besides the color maps. I can export the metalness but I'm not sure to which layer I should apply it. It has 30 layers called .._metalness and I don't know which to merge or how to deal with it...
Is there any way to just import and apply the painted textures in one step? Could I export the CC character with 3dxchange pro (not the Pipeline version) as obj, paint the texture in 3doat, reimport the obj into CC and reintroduce the moprhs/bones so that I could still pose the character? Just as a more convenient way to apply the textuers.
Thanks for the video, but I watched it before. It helped me with importing the diffuse map, but it doesn't deal with specularity or metalness.
Visits: 22.1K
PBR materials (used in iClone 7) have a metallic and roughness channels, so obviously you would use the correct map for each. If you have that many layers in 3D Coat that's a 3D Coat issue (in that program you can create as many layers as you want, but to export you should merge them all down into one. You might want to ask on the 3D Coat program the best way to proceed with that process). Unfortunately, OBJ export won't do PBR, so you can't just load it in and have all the channels done automagically for you, but it isn't hard to find each layer and to load it in separately. IIRC, 3D Coat even names the layers (so it will have a suffix like "_Metallic" and then you know which one it is).
ABeconis
ABeconis
Visits: 825
bela_sieck,you should really watch some beginner tutorials on 3D Coat. I stopped using it myself quite a long time ago, but if I remember correctly, there is somewhere an option to export textures with different profiles. That way all the layers are merged correctly and only the final textures are exported. Regarding empty specular, I think it’s because you are working with roughness (which you should for CC/IC7) and not specular, therefore you don’t have any information to export so - empty file.
