scott.hasse
scott.hasse
Last Active: 8 Years Ago
Visits: 100
kylelee
kylelee
Visits: 4.2K
I do not happen this issue, you can pass your issue to Feedback tracker. This issue seems like a bug, the photoshop layer should keep the layer order into CTA. Feedback Tracker: https://www.reallusion.com/FeedBackTracker/Product/CrazyTalk-Animator-3
scott.hasse
scott.hasse
Visits: 100
According to the CTA_G3_Whitepaper_Character_Creation.pdf document, section 3.5:
"If you encounter any layer order issue, then adjust the order in the PSD template documentbefore it is loaded into CrazyTalk Animator 3. CrazyTalk Animator 3 will list the body parts inaccordance with the order specified in the PSD file."
So it seems like the issue I am having with the order of the nose and mouth layers is wrong according to the documentation.
Anyone else able to duplicate this issue?
Thanks,
Scott
scott.hasse
scott.hasse
Visits: 100
Hi, all. I am currently working to create a G3 human character using the PSD template. I'm using Clip Studio Paint as a PSD editor and generally everything seems to be going fairly well. One issue I am having is that the nose on my character should be on a layer above the mouth. I have changed the layer order in both the RL_TalkingHead->HeadBone and RL_TalkingHead->HeadImage folders such that the Nose folder (and thus layer) comes before Mouth folder and layer. This displays properly in Clip Studio Paint, but after importing the PSD assets, Full Actor import the Nose ends up under the Mouth. I can change it manually via the Layer Manager in the composer, but this is going to be a pain as I am changing the character often.
Any advice for how to resolve this?
Thanks,
Scott
