cordonbert
cordonbert
Last Active: 8 Years Ago
Visits: 50
Hello, I was wondering if somebody could tell me where I can find a copy of Drawplus for Mac?
jlittle
jlittle
Posts: 1.9K,
Visits: 17.3K
I don't think DrawPlus was ever available for a Mac. They now offer Affinity Designer for the Mac but it does not have SWF export abilities, last I checked, so it was not a true "replacement" for DrawPlus at least for my needs for using it with CrazyTalk Animator. Jeff
garylearntech
garylearntech
Visits: 2.3K
@jlittle it would probably be more accurate to describe Affinity Designer as the successor to DrawPlus, rather than a replacement. :)@cordonbert given the low cost of a new Windows licence for DrawPlus (£20), perhaps you would consider using a Windows emulator solution? There are a variety of choices available ranging from free to about £100.
--- Cartoon Animator 4 Pipeline (always the current production version, unless otherwise stated) Mac mini M1, macOS Big Sur (11.6.5) Signature data last updated 2022-05-15
cordonbert
cordonbert
Visits: 50
Thank you garylearntech, I do have the crossover emulator, I wonder if anybody has any experience with it and if it will be stable enough to use properly.
garylearntech
garylearntech
Visits: 2.3K
cordonbert: I'm afraid I can't comment on that - it's years since the last time I ran Windows under emulation on a Mac. If you don't get any useful feedback from colleagues here on the Reallusion forums, remember that CodeWeavers have their own CrossOver Support forums - that might be a more productive hunting ground for your query? Good luck! Hah! Unable to leave things alone, I did a quick CrossOver forum search and found this recent post which looks promising…
cordonbert
cordonbert
Visits: 50
Thank you! I will try, see how it goes.... Affinity Designer sound nice too wish it would support SWF.
Save the spaceman
Save the spaceman
Last Active: 6 Years Ago
Visits: 4.1K
Hello if you go down the drawplus route, make sure you get drawplus 6 as 8 does not work with creating G2 characters! A lesson I learned the hard way!!!
cordonbert
cordonbert
Visits: 50
Thank you Save The Spaceman, I was going to go with Drawplus X8, still on the fence for the Affinity Designer app...
jlittle
jlittle
Posts: 1.9K,
Visits: 17.3K
Save the spaceman (3/7/2018) ... [DrawPlus] 8 does not work with creating G2 characters!DrawPlus 8 does work as long as you don't update it to the last version V14.0.1.21 I use V14.0.0.9 and it works fine for me with CTA. Jeff
Save the spaceman
Save the spaceman
Visits: 4.1K
Hello I've got to say affinity designer is pretty good! I do all my character creation in designer then transfer via Eps file to drawplus for the G2 template! I stand corrected regarding drawplus x8, thanks Jeff.
