[Upcoming] PopcornFX Plugin for iClone v1.01 - Bug Fixes & Enhancements
Posted By Grace (RL) 7 Years Ago
[Upcoming] PopcornFX Plugin for iClone v1.01 - Bug Fixes &...
Grace (RL)
Grace (RL)
Posts: 497, Visits: 5.1K
Issues to be Solved in iClone v7.21 / PopcornFX Plugin v1.01
Please see the following bug fixes and enhancements which will be included in the upcoming iClone 7.21 & PopcornFX Plugin v1.01 release by early Q2.
Grace (RL)
Grace (RL)
1. Bug Fixes - Rendering Related
  • The Ribbon Emitter normal, metallic, and roughness texture channels don't show up.  In the following illustration, when the same material is applied on the Ribbon Emitter and the Mesh Emitter, the Ribbon Emitter fails to render the proper PBR and normal effect.
75% of original size (was 672x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/d74fa6b5-9e70-4086-a480-290d.png
  • The Mesh Emitter has really strong AO effect when rendering videos and images.  This is due to improper ordering of the AO render buffer.
75% of original size (was 672x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/0cfcd8de-21a7-49dc-92c3-e106.png
  • When an undocked panel is picked, the shadows from PopcornFX particles become weaker and weaker - and can even vanish.
  • Strange transparent spots appear on the Texture Emitter when it intercepts with a Mesh Emitter.
  • PopcornFX distortion effect disappears when Exposure Bloom is set to maximum strength.
  • The Render Video/Image Layer disappears on certain operations or for specific PopcornFX content.
  • Visual defects appear when the camera is zoomed out or dollied out -the letters on the particle effect become disconnected, only partially showing.
  • No response when adjusting the Mesh Emitter Blend Mode to Solid Color Lit or when adjusting particle settings such as Lifetime and Start / Middle / End Opacity.
Grace (RL)
Grace (RL)
2. Upcoming Enhancements - Improved Operation and User Interfaces
  • Universal Adjust Color panel now available for PopcornFX Texture Channels.
75% of original size (was 672x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/58929622-dcd2-4631-af55-e763.png
  • The PBR metallic and roughness texture maps will be automatically generated when loading (*.pkfx) files for Lit Particle Material types. This is a convenient way to adjust the PBR look and feel of the effect in conjunction with the Adjust Color feature.
Grace (RL)
Grace (RL)
3. PopcornFX Super Tools Bug Fixes
The items below were reported as known bugs which we are working on fixing now. The updated PopcornFX Super Tools will be released together with iClone v7.21.
  • Texture & Distortion Emitter
    • To solve the orientation issue of Water Wake, the orientation of the Gizmo will be taken into consideration when the align mode is Horizontal.  Forum Report
  • Mesh Emitter
    • The rotation result is not correct when Forward To Velocity is disabled.
    • The emitted mesh will erroneously rotate when Spin Speed along Velocity is set to 0.
    • The attributes Scale Y & Scale Z are mistakenly swapped.
    • The behavior of Initial Rotate (X/Y/Z) and Free Rotation Speed (X/Y/Z) will improve by mimicking those of common 3D tools.  Forum Report
  • Ribbon Emitter
    • Radius Increment Fade Out" behaves incorrectly.
    • No effect from the green channel of the Texture for Emission which is used to determine the size of Ribbon
    • Results from Velocity (X/Y/Z) are incorrect.
    • No effect for the attribute Size Randomness.
    • Improvements will be made for the smoothing quality for the Ribbon Smoothness attribute.
