looping idle motion - first and last frame not equal - although I copied the first and pasted it in...
Posted By gm0124816 7 Years Ago
looping idle motion - first and last frame not equal - although I...
gm0124816
gm0124816
Senior Member (378 reputation)Senior Member (378 reputation)Senior Member (378 reputation)Senior Member (378 reputation)Senior Member (378 reputation)Senior Member (378 reputation)Senior Member (378 reputation)Senior Member (378 reputation)Senior Member (378 reputation)
Posts: 17, Visits: 103
Hi All,
iClone 7.2. Import a character. Go to MixMoves-Male (CC) and let the standing idle animation run one time (not looping).
Go to the motion layer, double click the first frame and copy it. Go to the last frame of the animation and paste it. They are not the same ! So, I cannot make it a looping animation. If I play it with the looping on, I get a small shift between the last and the first frame ... ... I added "off" value for spring in first and last frame, nothing happened ...
There are no gestures or any other stuff. Just the steps I mentioned.
What am I doing wrong ?
Threaded View
Threaded View
Forum Post looping idle motion - first and last frame not equal - although I... By gm0124816 ( 7 Years Ago )
Forum Post Are you referring to Stand01? Yes, there is a small motion root offset... By 4u2ges ( 7 Years Ago )
Forum Post Yes it is Stand01. Am I correct I need the "Curve Editor"-plugin to do... By gm0124816 ( 7 Years Ago )
Forum Post Oh sorry, I forgot the Curve Editor is not standard. Well, that is how... By 4u2ges ( 7 Years Ago )
Forum Post Thanks 4u2ges ! No, no particular reason for Stand01, it was just... By gm0124816 ( 7 Years Ago )
Forum Post If the feet don't move, try adding a second loop instead of using the... By Rampa ( 7 Years Ago )
Forum Post Another idea that might work is to add a reversed clip after the... By animagic ( 7 Years Ago )
Forum Post [quote]gm0124816 I did not look for the root in there. [/quote]... By Chuck23.C ( 7 Years Ago )
Forum Post @gm0124816 No problem and thank you for kind words about content :)... By 4u2ges ( 7 Years Ago )
Forum Post [quote]Find the spot where the root is (starting to move).... By Chuck23.C ( 7 Years Ago )
Forum Post Am I the only one who started to get a strong suspicion? :w00t: By 4u2ges ( 7 Years Ago )
Forum Post [quote][b]4u2ges (2/5/2018)[/b][hr]Am I the only one who started to... By animagic ( 7 Years Ago )
Forum Post [quote][b]animagic (2/5/2018)[/b][hr] No you're not alone in this... By 4u2ges ( 7 Years Ago )
Forum Post [quote][b]4u2ges (2/5/2018)[/b][hr][quote][b]animagic... By Kelleytoons ( 7 Years Ago )
Forum Post @Chuck23.C I looked it up and in the video created by Reallusion... By gm0124816 ( 7 Years Ago )
Forum Post There is a quick and effective way to set the same pose anywhere you... By Rampa ( 7 Years Ago )
Forum Post @Rampa Thanks for the video, it was interesting ! But I just tried it... By gm0124816 ( 7 Years Ago )
Forum Post I just played around with the Curve editor and Stand01 like suggested... By gm0124816 ( 7 Years Ago )
