sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
@mrbrush .... I'm happy for you about your mocap decision - and thanks for your input on this thread. I wasn't aware of the 're-tracking' of individual limbs feature, so I'll check that out today. I'm getting the 'impression' that there's not a *huge* difference between Reallusion, iPi and Brekel. They're all pushing the upper limits of what's possible with a single depth sensor. Personally I like the single depth sensor approach - it's quick and easy to set up. In order of 'speed of use' of the 3 softwares, I'm finding the following: ● Reallusion (easiest/quickest) ● Brekel (a tad protracted, though still reasonably fast) ● iPi (the longest approach time wise) Just 'capture' time here - I'm not factoring in the necessary *clean-up*. There's another "Cinema Mocap" but I think it can only work with *Unity* - (and not the free version of Unity) - correct me if I'm wrong please .... Anyway, keep us informed mrbrush - and let's know how you go with your mocap experience .....
Please be patient with me ..... I don't always 'get it' the first time 'round - not even the 2nd time! :( - yikes! ... ● MSI GT72VR Laptop, i7 7700HQ 4-Core 3.8 GHz 16GB RAM; Nvidia 1070, 8GB Vram ● iClone-7.93 ● 3DXChange Pipeline 7.81 ● CC-3 Pipeline 3.44 ● Live Face ● HeadShot ● Brekel Pro-Body ● Popcorn FX ● iRAY ● Kinect V2 ● DaVinci Resolve17 ● Mixcraft 8.1
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Well - there's only 'minutes' left on that iPi "special" .... and over the past 24 to 48 hours, I've had my finger on the *buy button* a couple of times, But the same's been true for the 'Brekel' mocap software - I went very 'close' to buying it .... Basically, I've been alternating and testing these three: ▪iPi ▪Brekel and ▪Reallusion ...again and again ..... My conclusion (atm) is - all 3 are to some extent 'hit and miss' approaches to capturing motion (based on using a single Xbox Kinect version 2). Without the *action* being viewed in profile by a 2nd sensor, the single perspective is all too easily confused. You *could* make a case for the 'superiority' of iPisoft's approach given the amount of controls you have to tinker with - but that comes at a price - "time" - and that kills the 'instant creativity'. The latest Brekel approach I personally *like* because it's much quicker with less steps involved. It simply feels like more 'fun' to use - nice UI - easy to operate. (can detect multiple actors too). But none of the 3 produced results I've been overly happy with - and with iPisoft and Brekel, I didn't know for a certainty what I'd captured until importing it into iClone. Even the behavior could change from xChange to iClone - not very reassuring .... (maybe it's me and the settings I'd used). And that's the *plus* of the 'jitter bug' - (iClone's resident mocap software). Yes it can behave in strange ways - but it's WYSIWYG, so you're not left guessing. If it's a bad take - you know straight away, - If it's a good take - it's not going to change - it's right there where it's needed, in iClone. I've done a couple of tests with 'condensing' a native iClone motion capture - then re-expanding it to reduce the density of the original key-frame count - and you can get some nice results. I saw a video on this here: https://m.youtube.com/watch?v=CV_cwq9Jg0sNot sure - but it might have been suggested by Rampa - in the comments section under this Youtube video, Rampa stated: ".....So I just discovered that the "Direct Puppet" has a significant smoothing effect. It will save you having to save and reload. Use it without actually doing any "puppeteering", and you'll end up with a new clip that just replaces the old one "in place". You can record across multiple clips, and they will be combined into one. It's like doing a mix-down. :) You could also try it in combo with the squish/stretch, and running multiple times....." I'm yet to test this part myself... For me (atm), a 'single' Kinect sensor approach is as far as I wish to go. For that, I feel the instant/immediate feedback from iClone's mocap capture is a plus and it's perhaps worth 'putting up with' the jitters. Probably *many* extra takes will be needed to get that ONE jitter free shot, but would still be faster than using a separate app > Xchange > iClone > oh dear it's not right! > start over again ..... I think I'll continue tinkering with the Brekel trial to see if I can get some predictable iClone imports (the avatar seems to 'drift' once inside iClone). Steve.
Visits: 22.1K
Steve, My biggest issue with Kinect captures that were NOT in iPisoft (and this may have changed -- I have not tested Brekel in years, although the RL plugin is the same one it's been since it was first released) was with the feet. RL's plugin is practically worthless when it comes to lower body capture unless you are *extremely* careful (and even then -- you will get tons of foot sliding). That's where something like the PN has these systems beat -- foot planting is easily accomplished. For upper body motion only Kinect is a pretty good solution, even a 1 camera version. And, of course, as I mentioned earlier the other weakness of Kinect (as well as the VIVE hardware) is area size, something again that a PN suit (or some other capture suit) will easily handle. But that goes hand in hand with the idea that as long as you're happy with upper body motion there's no real reason to look beyond a Kinect solution. I'll be interested to see how you feel a few years down the road (assuming I'm still around). Again, not to repeat myself but as humans we always want to improve, and mocap is one of those areas where the technology is better the more you spend. I'm going to guess that if you keep animating you will also keep redoing and refining your workflow, and changing your hardware <g>. I know I have.
mr brush
mr brush
Visits: 1.1K
I did have the brekel about 2 years ago and for me it was useless. A guy called Jasper refunded my money and he was a nice guy too. I never tried the reallusion plugin but the ipi takes only a couple of minutes to set up and seemes to give the best results judging by the youtube videos when i compared the two. Sorry brekel is out of the running for me.
gordryd
gordryd
Last Active: 3 days ago
Visits: 8.0K
KT - awhile back it sounded like you were going to do a write-up comparing HTC Vive, PN, and (?) something else. Is that in another thread somewhere -- I am very interested in the results. - Thanks
Visits: 22.1K
Yeah, I was intending to compare what I consider to be "the big three" -- VIVE/Ikinema, Perception Neuron, and Kinect using the 2 camera iPisoft software. These three systems produce excellent mocap but otherwise are about as different as can be. I guess I can still write up my thoughts -- I pretty much figured most folks weren't interested.
Posts: 15.8K,
Visits: 31.4K
Although I eventually will want to get Perception Neuron, I decided to make use of the iPi offer, as I have a Kinect 2 lying around. It will be October until I can try it out.
gordryd
gordryd
Visits: 8.0K
@KT - Seemed like you were heavily leaning towards Vive and then something changed, and now you seem to be favoring PN - what changed your mind?
Visits: 22.1K
It's in my thread about the VIVE, and probably best to look at it there in full context. But the short answer is that I had tracking issues that couldn't be easily solved AND I realized that hands captured simultaneously are a HUGE part of what we need in mocap. For the same price (due to the subscription software the VIVE required the PN amounts to the same price) you get much better tracking AND hands. Not to mention there are no space limitations. None. It's kind of a no-brainer.
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
iPisoft: - Three versions *Express *Basic and *Pro - but the "Realtime Tracking" feature IS ONLY AVAILABLE in the more expensive "Basic" and "Pro" versions (NOT in the cheaper "Express" version - $195). (iClone's Mocap already has "Realtime Tracking" built in) ... iPi's *strength* comes from their dual sensor setups imo ("Basic" and "Pro" versions) - but that's expensive for the small guy - $695 minimum, plus 2 x Kinect sensors plus 2 x power supplies, tipping you over $1,000. Brekel: In a *non-ideal* environment with un-even lighting and barely visible floor reference, I was able to get more pleasing results with Brekel than with iPisoft (single sensor used). Brekel's current offering only allows for a single sensor to be used. The testing I did was with their "Pro Body V2" (at $139.00). iClone: iClone's Mocap is $79 (member price). It's real-time, straight to the time-line. It is subject to excessive jitter even with the smoothing control set to maximum. 'Stable' (non-jittery) results are undoubtedly *difficult* to obtain - but I found iPisofts's "single" sensor ("Express") package also 'difficult' to obtain stable results from. These are my personal findings and 'mileage *may* vary' depending upon your own setup / environment / settings used. Non stable (jittery) captures simply mean manual 'clean-up' is needed. Would be great if others using the Kinect v2 would share their experience / advice as well. :)
