Does anyone know these particles in Popcorn FX?
Posted By Postfrosch 8 Years Ago
Postfrosch
Postfrosch
Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)
Posts: 6.9K, Visits: 18.4K
Hi Guys,
I bought Popcorn FX with the Essetial Pack Libary40
I'm so happy with it. So far so good
I have in this advertising clip from RL
https://forum.reallusion.com/uploads/images/567d111e-46a1-4923-8fad-8df2.jpg
seen these 2 FX effects.
https://forum.reallusion.com/uploads/images/59e20054-927a-49cf-af01-4366.jpg
https://forum.reallusion.com/uploads/images/6438ec25-382f-483d-af53-2fbb.png
  Unfortunately they are not to be found in the things I bought.
  They are also not listed in the enumeration of the FX Learning Sample 50
You can not find them in the popcorn editor either.
Hence my question. Does anyone know or have these FX particles
or was that just advertising again? Would be a pity.
One more warning:
https://forum.reallusion.com/uploads/images/9f91657a-1266-4242-b066-e4cb.jpg
If you have this FX from the Popcorn.Editor via PlugIn to IClone
and run it there, then crashes IClone 7.2. (At least with me)
Greetings from Germany
Rogue Anime
Rogue Anime
Posts: 548, Visits: 3.4K
PostFrog - I have not used the first one yet - it is called "Music Ball" - it is SUPPOSED to react based on your music track, I believe. & it is located HERE.  ~V~
https://forum.reallusion.com/uploads/images/96a935c4-6abb-4c22-b321-13c4.jpg
       Val RogueAnanda
https://forum.reallusion.com/uploads/images/e82de505-c57a-40b9-8cb0-9f87.png
Postfrosch
Postfrosch
Thank you for your answer.
I know the FX that you show me and that is not one of the two.
The first picture shows: Spark Ermitter
The second picture: Skinned Water
Both FX are not to be found.
Grets from Germany
Postfrosch
Galfridus
Galfridus
Posts: 727, Visits: 2.2K
https://forum.reallusion.com/uploads/images/51e9facf-2ef3-4715-a6f2-15a2.jpg
https://forum.reallusion.com/uploads/images/11377f14-0be6-4e4d-954e-6a13.jpg
https://forum.reallusion.com/uploads/images/1203e104-ab58-4a08-8f8f-15ed.jpg
Geoff.
https://forum.reallusion.com/uploads/images/ba17ca1f-2bbe-4b61-819c-6bdf.png
Postfrosch
Postfrosch
Hallo Galfridus,
Thanks for the answer.
The first clip is just the Reverenz in which I the other two
FX discovered. I knew the music ball from the beginning.
I did not find the other two FXs.
I'll try the water.
I'll also get the learning package
Postfrosch
Postfrosch
Postfrosch
Doppel
Postfrosch
Postfrosch
Hallo Galfridus
So I do not think that's the effect
"Flick Water" was used in the promotional clip.
The effect is called "Skinned Water" in the clip
Look at the two pictures with their respective attributes.
The FX effect "Skinned Water" (up) has very different attributes than "Flick Water" (down)
https://forum.reallusion.com/uploads/images/5ac08e11-82e8-4032-8d67-d699.jpghttps://forum.reallusion.com/uploads/images/7b635a7e-b56a-4030-bd3f-bff5.jpg
uind also gives a completely different effect. I just tried
Look the RL-Clip
https://www.youtube.com/watch?time_continue=2&v=jInOQ4a--MU
Greets from Germany
Postfrosch
Galfridus
Galfridus
https://forum.reallusion.com/uploads/images/d2654809-69a8-4ae5-8918-c269.jpg
I thought the purpose of the video section you mentioned was to illustrate that particles could be emitted from soft cloth.
In the video example water flicked out from female clothes.
Use the Flick Water FX and select which item of soft cloth (or any other mesh) you wish to emit the water droplets.
Then adjust the parameters.
Geoff.
