Galfridus
Galfridus
Visits: 2.2K
 I thought the purpose of the video section you mentioned was to illustrate that particles could be emitted from soft cloth. In the video example water flicked out from female clothes. Use the Flick Water FX and select which item of soft cloth (or any other mesh) you wish to emit the water droplets. Then adjust the parameters. Geoff.
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Hallo Galfridus So I do not think that's the effect"Flick Water" was used in the promotional clip. The effect is called "Skinned Water" in the clip Look at the two pictures with their respective attributes. The FX effect "Skinned Water" (up) has very different attributes than "Flick Water" (down)
uind also gives a completely different effect. I just tried Look the RL-Clip https://www.youtube.com/watch?time_continue=2&v=jInOQ4a--MU Greets from Germany Postfrosch
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Doppel
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Hallo Galfridus, Thanks for the answer. The first clip is just the Reverenz in which I the other two FX discovered. I knew the music ball from the beginning. I did not find the other two FXs. I'll try the water. I'll also get the learning package Greetings from Germany Postfrosch
Galfridus
Galfridus
Visits: 2.2K
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
I have not used the first one yet - it is called "Music Ball" - it is SUPPOSED to react based on your music track, I believe. & it is located HER Thank you for your answer. I know the FX that you show me and that is not one of the two. The first picture shows: Spark Ermitter The second picture: Skinned Water Both FX are not to be found. Grets from Germany Postfrosch
Rogue Anime
Rogue Anime
Visits: 3.4K
PostFrog - I have not used the first one yet - it is called "Music Ball" - it is SUPPOSED to react based on your music track, I believe. & it is located HERE. ~V~
Val RogueAnanda
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Hi Guys, I bought Popcorn FX with the Essetial Pack Libary40 I'm so happy with it. So far so good I have in this advertising clip from RL
 seen these 2 FX effects.
Unfortunately they are not to be found in the things I bought. They are also not listed in the enumeration of the FX Learning Sample 50 You can not find them in the popcorn editor either. Hence my question. Does anyone know or have these FX particles or was that just advertising again? Would be a pity.
One more warning:
 If you have this FX from the Popcorn.Editor via PlugIn to IClone and run it there, then crashes IClone 7.2. (At least with me)
