Problem with Curve Editor
Posted By Terry Miller 9 Years Ago
Terry Miller
Terry Miller
Posts: 96, Visits: 2.2K
Hello all, hope you had a nice holiday.
Running into a problem with the curve editor.
When they are using it in the tutorials, all the tutor has to do is push the FK Mode button and the FK Mode UI pops up; then, if he wants to select a particular body part, he selects it in the FK UI, and the curves for that body part shows up. Wonderful, right?
Unfortunately, I can't get it to work that way. If I click the FK Mode button, nothing happens; I have to open the Edit Motion Layer UI and manually select FK; then, if I want to select a body part, when I click it in the FK UI, the curves do not pop up in the editor. What I have to do is find and select each individual body part from the entire list of bones in the curve editor. Needless to say, this takes a lot more time than it should. I would like to make sure that I am not doing something wrong before I submit it as a bug. As always, any help is greatly appreciated.
Thanks,
Terry
CVEDIA
CVEDIA
Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)
Posts: 2, Visits: 120
I can't visualize the curve editor window, anyone knows how to solve this problem?
Posts: 15.8K, Visits: 31.4K
It's a separate plugin. Did you buy it?
If so, maybe explain in more detail what you are doing.
dogged2003
dogged2003
Posts: 418, Visits: 4.5K
Did you make "Sample animation clip" the movement before calling the Curve Editor?
For which version of the avatar are you trying to do the above?
Terry Miller (12/28/2017)
Thanks,
Terry
My YouTube channel.
